Oil Filter Change
Old Nov 18, 2002 | 03:59 PM
zul8r2002's Avatar
Smile Oil Filter Change
Can i change oil filters without changing oil???
Will I get alot of leaking and loss of oil from changing???
ANYONE????
THANX!!!!
Old Nov 18, 2002 | 04:15 PM
2002Z28SSConv's Avatar
nope. It won't leak anymore than when you changed the oil. The level of the oil in the pan is below the top of the filter.
Old Nov 18, 2002 | 04:32 PM
LS1CAMARO's Avatar
I change my filter at 2500 miles then do a full oil change at 5000 miles. I use 10-30 Mobile One Syn.
Old Nov 18, 2002 | 05:16 PM
zul8r2002's Avatar
Does alot of oil drain out when you change filter??
Old Nov 18, 2002 | 05:42 PM
LS1CAMARO's Avatar
A little does, you will need to top off the oil.
Old Nov 18, 2002 | 07:22 PM
MRZ28HO's Avatar
Try this to prevent making a mess. Use a flat blade screw driver with a hammer to make a small puncture on the under side of the filter. This will drain out the oil that is in the filter, so that when you unscrew the filter, the excess won't spli out the side and make a mess.
Old Nov 18, 2002 | 11:10 PM
Capn Pete's Avatar
Thumbs up
^^^ that's a good idea! I've never thought to do that before.................I may give that a try next time I change the oil (which is due in about a week or two ).
Old Nov 19, 2002 | 10:08 AM
bbentley40's Avatar
Its a good idea.. and it will work.. however it is sometimes difficult to get under the car hold a screwdriver and whack it with a hammer. As if that is not hard enough, if you dont hit it head on the screwdriver might slip and end up hitting something else. So if you use this idea just be careful. But I have done this before and it works great. It is also a handy method if you dont have a filter wrench and it doesnt want to come off.. just drive a screwdriver through it and turn the screwdriver.
Old Nov 19, 2002 | 11:52 AM
rncotton's Avatar
Been there .... done that.
Old Nov 19, 2002 | 11:36 PM
BlueLS1Z28's Avatar
good idea,i use an ice pick,you don't need a hammer for that
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
Dmonty
Jun 2, 2015 11:19 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
