Oil 2 quarts low...WTF!!!
Old Aug 29, 2003 | 07:27 PM
RxNupe's Avatar
Angry Oil 2 quarts low...WTF!!!
I drove from Chicago to Memphis this past week and added ~1200 miles to my odometer. I checked my oil prior to leaving and it was fine. Got up this morning and my low oil light was on. Went to get an oil change and the tech said it was about 2 quarts low. He said he noticed no visable leaks. Sounds like a warranty issue to me. What could be going on? The car now has about 25k miles.
Old Aug 29, 2003 | 07:42 PM
KwikistZ's Avatar
Re: Oil 2 quarts low...WTF!!!
Your car COULD be burning oil
Did you look for white smoke? And did YOU check for leaks?
Old Aug 29, 2003 | 08:03 PM
Lan01z's Avatar
Mine did the exact same thing! I figured out that it was only when I went into the higher rpms. 4k+ I used to have my low oil light come on after 2500 miles.
Old Aug 29, 2003 | 09:28 PM
rixz28's Avatar
I went thru 3 quarts in 4000 miles but I did 10+ runs at the strip. Normally I go thru 1-2 qts. every 3-4K. I shift at 3000-4000 all th etime which will probably cause more oil usage. I have an extended warantee so when it gets REAL bad I'll bitch.
Old Aug 29, 2003 | 10:12 PM
ULTIMTEORANGESS's Avatar
anything more than 1 qt at 3k is BS.some tend to use less after the mileage goes up due to people running syn. oil right from the start and it slows down engine breakin.
mine uses a little between changes but nothing to be worried about.i would think if it was leaking that much oil youd smell it dripping on the motor.id have GM look at it.
Old Aug 30, 2003 | 01:37 AM
AL SS590 M6's Avatar
Moderator
Change your PCV valve. It sticks and sucks all of the oil out of the pan. My 2000 did the same thing. Used 2 qts in 1200 miles. Changed the PCV and it hasn't used a drop since.
Old Aug 30, 2003 | 11:56 AM
rncotton's Avatar
Well, a few things.
First, the M6 uses more oil than the A4. Us M6 guys tend to keep motor revving higher and in the upper end of the RPM range for longer periods of time.
As for the PCV, there is a redesigned "Fixed Oriface" PCV that you can get from the dealer. It eliminates the valve inside and simply uses a fixed diameter hole to regulate the flow. I swapped to the new design and although it didn't help me, it has helped others.
Good luck.
Oh, the new PCV is part # 12572717. If they tell you it won't work on your car, tell them to give it to you anyway. I *think* it's for the 6.0L truck motor.
Old Aug 31, 2003 | 02:06 PM
Ferocity02's Avatar
When I change my oil, I put in 5.5 quarts. 500 miles later I will add the other half-quart. And the other day, about 300 miles short of the 3000 mile mark, I added a little short of a whole quart. I usually shift under 2k RPM.
realistyc
Jul 28, 2015 07:32 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
