Odd noise after putting 18x9.5's on...
Old Oct 25, 2003 | 06:25 AM
Desolate_Flux's Avatar
I bought a Z06 replica package from AFS, the wheels are 18x9.5, with Kumho's on it. Kumho 712 Ecsta Supra tires – 275/35 ZR-18
Link to product info here - http://www.afswheels.com/v2/ecommerc...exd.asp?id=106
They look great, they fit great, I love them.
But get this. Sometimes, when I take a turn, not a tight one, not a loose one... Nothing particularly trackable... from the rear end you get a metal on metal kind of humming noise. It kinda sounds like when you rub your finger around the opening of a glass pepsi can (Or a Corona, if that suits you guys better) - and it goes away after the turn.
My wheels are snugly on, and they were put on properly with every bit of caution to doing it right one could have. Sounds axle related, but why? Theres plenty of clearance, I dont believe the tire is rubbing - and even if it was it wouldnt sound like that.
My car isnt lowered, it doesnt have any other kind of suspension modifications.
What do you think?
Old Oct 25, 2003 | 02:57 PM
Lan01z's Avatar
Re: Odd noise after putting 18x9.5's on...
What do you think?
I also have the z06 18x9's from afs. Its probably just the rims making noise. Mine do the same thing around corners, but only if I take them at 30 or so. I also hear a slight "hum" at 40-43 mph, then it goes away into the 50 mph range. I wouldnt worry about it
Magenta_Hearts
Mar 25, 2015 10:24 AM
WildRidez
Feb 23, 2015 07:24 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Fatdog2
Feb 12, 2015 12:24 PM
squarehead
Nov 21, 2014 08:02 PM
