Octane
Re: Octane
Sun Ultra 94.
The car runs good on it. I run 94 in my bike and can feel a better
pull.
My Harley friends don't use Exxon becouse of the dye in the gas. It
gums up the injectors. So I don't use Exxon in the Camaro either...
Jim
pull.
Jim
Re: Octane
I think 116 is leaded and if you put it in your car it will mess up your O2's. I do know they make 100 in an unleaded version, but unless you are running high compression I would stick with 93.
Re: Octane
Re: Octane
93, because I have not increased my engine's compression ratio or added a power adder. With no such reason to increase the risk of detonation, you would not need anything higher than 93 in a properly functioning engine. Higher octane is more $$$$, don't waste it on gas when you can spend it on mods later.
Aug 24, 2015 06:41 AM
