O2 connector
Old Mar 22, 2013 | 07:39 PM
dalynchmob's Avatar
O2 connector
I recently purchased a 2000 SS and it had a SES. Ran the codes and it cam up with skip shift soleniod, MAF, and all 4 O2s. Replaced the MAF with a known working one i had from my 94 LT1 (same part #) and still had the code for the MAF. Did some research and learned about the ENG SEN fuse and checked it, blown. Replaced fuse and it popped immediately so i figured i had a ground or melted wires issue. Check the O2 wiring and found it. Passenger side downstream sensor wires a melted mess. Apparently the previous owner had either damaged the O2 plug from the harness or purchased a sensor with the flat connectors and instead of taking it back and getting the correct one, cut the plug off the harrness and the sensor and wired them together with elctrical tape. The wires were only melted from the sensor to where the sensor plug had be cut off. The wires from the harness are fine.
So my question is this. Does someone sell a harness plug that i can wire back onto the harness? Or can i purchase a O2 extension wire and use the end from it? Then i can get a new sensor and "plug'' it in the correct way.
Old Mar 22, 2013 | 08:30 PM
rv93's Avatar
Re: O2 connector
the up and downstream sensors are the same, so connectors are the same as well. numerous companies make extensions for the upstreams (needed for lt headers). something like this
LS1 F-Body O2 Extension
or you can always go on ebay and probably find it cheaper.
Old Mar 22, 2013 | 08:49 PM
dalynchmob's Avatar
Re: O2 connector
Ok thanks, i also might just have them tuned out. Going with headers soon anyways and my seepdo if off from the 4.10 install so i was already planning on sending it out to get that corrected.
Old Apr 7, 2013 | 03:32 PM
rv93's Avatar
Re: O2 connector
might as well get them tuned out, yeah. as long as you dont have emissions testing, it wont hurt anything
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
