NGK Plugs
Old Oct 22, 2003 | 09:40 PM
Fred94LT1's Avatar
NGK Plugs
All you guys running NGK TR55 Plugs what are you runing for a gap? I realize the factory gap on the stock platinum plugs is .060. I pulled my 100K stock AC plugs with 33k on them to find them at .070-072. I also installed some MSD 8.5 wires, I set my NGK's at .055.
Old Oct 23, 2003 | 12:17 AM
ponystomper's Avatar
I gapped mine @.050
Old Oct 23, 2003 | 02:00 AM
coogsLS1's Avatar
what difference does gapping make?
Old Oct 23, 2003 | 10:08 AM
Greed4Speed's Avatar
How would a tighter gap than recommended be beneficial? That was a big deal w/running aftermarket ignitions was to get a larger gap.
Old Oct 23, 2003 | 10:28 AM
Import_Eating_Z's Avatar
I am Running Bosch Plat +4 plugs with ThunderVolt wires and I left them at the factory .060 . I personally can’t understand why you would gap them less ? More I might could see.
Old Oct 23, 2003 | 11:40 AM
TedH's Avatar
I gap my NGK TR55IX's at .050. A larger gap makes a bigger bang but is far more prone to misfires if there are any problems in the electrical system.
Old Oct 23, 2003 | 04:00 PM
demonspeed's Avatar
Very good question. I was wondering the same as I wanted to do a tune up this weekend. I bought the TR55's and was debating between 55 and 50
Old Oct 23, 2003 | 05:10 PM
camaro322hp's Avatar
my TR55's came out of the box at 0.055" i left them there and installed them.
Old Oct 23, 2003 | 10:43 PM
coogsLS1's Avatar
well, if .060 is stock, would .070 be more bang? How come you guys are going with .050 then?
Old Oct 24, 2003 | 05:38 AM
Fred94LT1's Avatar
As TNTHUB said the more the gap the better the chance to get high RPM's misses. I also knew that with time progressing that the gap on them will grow. I didn't want to have to ghange my plugs again within the next 10,000 miles. With the addition of the 8.5 wires I should be getting plenty of fire(spark) to the cylinder. Most guys who run N2o will go with a shorter gap as well as the n2o has less of a chance to extinguish the spark that way. Just my opinion,
Old Oct 25, 2003 | 02:35 PM
coogsLS1's Avatar
which is?
Old Oct 25, 2003 | 05:41 PM
tekker's Avatar
stock (.060) maybe?
/tek.
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
