Need to upgrade Clutch
Old May 30, 2005 | 09:06 PM
Schmidt519's Avatar
Recently, I have felt my clutch hasn't been hooking up 100% through the gears. With the added HP i'll be getting with my cam/pulley/iLS6 intake manifold install and tuned early June, I have a feeling it's not going to last much longer. Don't know which clutch will work best with my setup. Which should be in the 385-400 RWHP range. Any recommendations on good streetable clutches that can handle that kind of power?
Old May 31, 2005 | 06:28 AM
teke184's Avatar
Re: Need to upgrade Clutch
my Spec 4 is great on the street.
even brand new it had almost no clutch chatter and now tht it's breaking in there is even less.
although i've heard it's not a good clutch for city traffic, when it heats up it gets really grabby.
the Spec 3 would probably do you fine.
Old May 31, 2005 | 01:06 PM
Schmidt519's Avatar
Yea, I never do any city driving. I think the Spec 3 will be a good choice for the street, that or maybe the Z06 clutch. Also what about the flywheel, should I get a kit that includes everything including the flywheel. Thanks for the help, I need to order one today, so that it will be installed before the cam.
Old May 31, 2005 | 01:31 PM
Schmidt519's Avatar
Just ordered the Spec Star Clutch Kit Stage 3 w/ flywheel LS1. It includes the LS1 Star Clutch, billet steel flywheel, clutch disc, pressure plate, throw out bearing, and alignment tool. Is there any thing else I going to need for the install, such as new adjustable master cylinder for an 00 Z28.
Old May 31, 2005 | 03:06 PM
teke184's Avatar
i'm pretty sure the 00 still benefit from the upgraded slave cylinder.
something about the older ones was inaddequate. they are around $140 from any of the site sponsors.
ducttape1975
Jul 10, 2015 06:29 PM
mrwz28
Jul 8, 2015 09:11 PM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
