Need some more horsepower...help!
I have a '98 Z (check sign. for mods.) and I'm purchasing a SLP lid w/ KN air filter, new plugs and wires, and a shock tower brace.
I know this will add some horsepower but what can I do after that?
Would getting a cutout be a good idea?
Maybe running without any cats....if some how do I do this?
Also, I'm not ready for a cam yet, my car is an everyday driver and I don't have time to put one in or have it done. I guess I just want bolt-ons.
One more question..with my new additions, what kind of hp gains I'm I looking at?
Thanks.
1998 Z28. Artic White.
Thanks.
- SS hood
- Sport Appearance pkg.
- Ported, Polished MAFH
- Free ram air Mod.
- Flowmaster Exhaust
- Custom Stainless tips
- T-tops
- Fully loaded
The mods you have in mind are almost a must. As far as the cats are concerned, gutting mine gave me a little more power and an even throatier sound as well. One thing I'd recommend is the low temp thermostat, it's farely inexpensive and worth the money. If your car's and automatic and if you can save up, I'd say by far the best thing you could do is upgrade your torque converter. I know this isn't really a bolt-on, but it will totally change your car. You can look at my sig for all my mods. The Vigilante was about the only thing that I could really "feel" the added HP from. My car is also my daily driver.
1998 Z28 (A4)
Granatelli Airbox Lid,
K&N Filter,
Granatelli MAF Sensor,
160* Power Stat,
Hypertech Power Programmer III,
NGK TR-55IX Spark Plugs,
Taylor 8mm Wires,
Fast Toyz Ram Air,
SLP Strut Tower Brace,
Vigilante Torque Converter (3200 stall),
Richmond 3.42's (from stock 2.73's),
Summit Rear End Girdle,
Gutted Cats,
Flowmaster Cat-back Exhaust,
Nitto Drag Radials
1998 Z28 (A4)
K&N Filter,
160* Power Stat,
Taylor 8mm Wires,
Fast Toyz Ram Air,
Gutted Cats,
Nitto Drag Radials
<font face="Verdana, Arial" size="2">Originally posted by Camille:
One thing I'd recommend is the low temp thermostat, it's farely inexpensive and worth the money.</font>
http://ls1info.com/article.php?sid=180
The lid and all the free mods should be next.
Then the only place to go from there is a set of Hooker LTs.
A converter if you have an A4, a 4.11 gear if you have an M6.
Along with the free t-stat mod, install an automatic fan switch on you car as one mod does little without the other. This mod is not free, but it is only about $20.
Good luck,
Dave
Re-read that article goofy, it's not "FREE." It is however inexpensive...just like I said.
1998 Z28 (A4)
K&N Filter,
160* Power Stat,
Taylor 8mm Wires,
Fast Toys Ram Air,
Gutted Cats,
Nitto Drag Radials
1998 Z28 (A4)
K&N Filter,
160* Power Stat,
Taylor 8mm Wires,
Fast Toys Ram Air,
Gutted Cats,
Nitto Drag Radials
Okay...
Where's this "goofy" **** coming from?
Did I attack you? I thought you were refering to one of the aftermarket t-stats. If I was mistaken, I'm sorry.
Also, I didn't spend any money on this mod. Just dropped in the shim and poured the coolant back in the car when it was back together.
Next time you post about the free t-stat mod, say "t-stat mod", don't say "buy a low temp thermostat"... they mean two different things newbie.
Dave
Dave
<font face="Verdana, Arial" size="2">Originally posted by Freak:
Long tube headers</font>
Youll need a new Y yes, but most of the favorite headers (FLP, TTS, SLP, and Hooker) have y pipes either included or available.
'99 Z28 M6
B&M Ripper, Direct-Flo, Lid, Borla Cat Back, McCord Powerplate, Fast Toys Ram Air, !CAGS, !EGR, TB Mod, LS1 Edit
SLP SFC's, Lakewood LCA's, Polyurethane Trans mount and Torque arm bushing
Hooker Long Tubes with custom 2.5 inch off road Y-pipe into a Flowmaster collector
Comp Xtreme 224/224 568/568 112 LSA
Moser 9 inch Housing/Axles with Ford Trac-Loc 3rd Member and 4.11's
Bi-reciprocating dingle-arm to prevent side-fumbling in the turbo-fam
"Fear not the bullets, only the holes they make"
"Vegitarian is Indian for lousy hunter"
"Life is a sexualy transmited disease with a 100% fatality rate."
"You're talking to my guy all wrong. Tone's wrong. You do it again, I'll stab you in the face with a soldering iron."
"If the Army and the Navy ever look on Heaven's scenes, they will find the streets are guarded by United States Marines!"
"It's God's job to forgive Osama Bin Laden. It's the Marine Corps job to arrange that meeting."
'99 Z28 M6
Get a lid....95 dollars and you will get 10-15 HP, half the gain of long tubes for under 100$$$$. It will como\pliment your FRA well, too!
2001 red Z....M6, Borla cat-back (1.5 inch), AMS lid, Home ported MAF, SLP CAI and KNN.
Corrected HP(Rear Wheel) 327!
Corrected Tq (rear Wheel)338! WOW!
NOT underrated, my A$$!
You never stated if you had a M6 or auto, so if it is an M6 go with an aftermarket shifter such as the B&M Ripper, Pro 5.0, Lou's, etc. As you up the ponies, a nice set of subframes would be a good choice.
99 Hugger Z28
FTRA, HPPIII, Holley Powershot, 160 stat, Whisper Lid
Thundervolt wires, NGK 55 plugs
B&M Ripper, Skip shift elim
SLP Resonator, Mac True Fit Headers
BMR LCA's, BMR STB, SLP SFC's
Bilsteins all around.
Vision 212s, Kumho Ecsta 275/45-17s back, 245s front
MTX Thunderform
"A mans got to know his limitations." Harry Callahan
www.netsnapshot.com/pcw/buildalbum-cgi?ACCOUNT=1053&KEY=0
99 Hugger Z28
MTX Thunderform
[QUOTE]Originally posted by Tucdog:
[B]You never stated if you had a M6 or auto, so if it is an M6 go with an aftermarket shifter such as the B&M Ripper, Pro 5.0, Lou's, etc. As you up the ponies, a nice set of subframes would be a good choice.
I have an auto. And I really don't want to go with a larger gear or a stall converter yet. Maybe when I'm a little older and the car becomes a weekend driver!
Thanks.
Thanks.
You could go with a 2800 stall Vigilante, and it would be very streetable. You can shave off .4-.5 in the 1/4 consistently, and it will still be very reliable for you. That will give you the best gain of all the bolt-ons out there for an A4.
As for headers, I really like the FLP kit. It comes with longtube headers, complete y-pipe, and interchangable off-road pipes and hi-flow catalytic converters. That's the awesome part with the FLP's: you can swap the cats out for the off-road pipes whenever you feel like it. The headers and y-pipe have been ceramic coated as well, so they look great, too. We carry them here at L.G., so feel free to give me a call if I can get a set coming to ya!
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
Check out the SS!
