Need to replace fuel pump............
Old Apr 16, 2003 | 09:53 PM
scottmech's Avatar
Got a 98 Z28 and need to replace the fuel pump. What has to be removed to get the fuel tank out?
Any info appreciated.
Old Apr 16, 2003 | 10:17 PM
Bone Maro's Avatar
Two options.
1) Drop the rear suspension and tank
2) Cut a hole in the top of the back deck and removed from the top.
Old Apr 17, 2003 | 12:14 PM
scottmech's Avatar
Ended up cutting a hole in the deck. I tried this on a older f body and found the pump had ridgid lines all the way down the outside of the tank. I didn't realize you caould do it on the newer ones.
Thanks for the help.
Old Apr 17, 2003 | 02:12 PM
asianice25's Avatar
Id get a chiltons, and drop the tank. cutting anything on my baby doesnt ever sound good. Go to the library and get a manual on a 4th gen, and it should be relatively the same. If you get a book on a 94-97 f-body, theres no carbon canister in back, and a couple other differences i believe. Try doing a search on here and ls1tech to see if theres any instructions on how to drop the tank. might as well go a bit bigger with the pump too. maybe a walbro or soemthing, its a direct replacement i think...like 140 bucks or so.
Old Apr 17, 2003 | 02:54 PM
scottmech's Avatar
Don't mind cutting a hole in mine. I used to be a sheet metal mechanic at an airline so sheetmetal work is second nature to me.
That and the fact the car isn't a show car, just my everyday driver. So the less time it's off the road the better.
To each their own.
Old Apr 17, 2003 | 03:09 PM
asianice25's Avatar
Thats cool, i didnt know you were an expert. I would still think about replacing the it with an aftermarket piece. How much is a stock fuel pump? at least 100 id imagine, and the aftermarket ones can be had for not much more.
kaoticcamaross
Feb 17, 2015 03:13 PM
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
ANDYZ28
Dec 29, 2014 09:13 PM
