Need electrical HELP!
So after driving my car couple times in the day, my last trip i made a 15min stop, turned car off, left my blinkers on. When i went to start it up it was dead. Just click! Guages are dim and only reading 9volts and acting like its dead. So i try quick jump, does nothing, guages still dim, acts like out of power, but windows work ok and lights seem to be bright. So checked battery with voltmeter while car in "on" position, 12.1volts while guage is still only reading around 9volts. I cant figure this thing out hopefully someone can point me in the right direction? (no corrosion on or around battery)
oh sorry! thanks for your help guys. The cars sitting in parking lot so i went last night while stores closed took a look under the car. Snapped 2 motor mount bolts (one being battery to block ground) so problems been found... noow i guess for my next nightmare! removing to broken studs from block
tdigger9899
Sep 7, 2015 10:56 AM
