My suspension feels horrible!
Old Apr 17, 2003 | 04:34 PM
  #16
badeSSt's Avatar
I have the bmr weld in sfcs and they rock, they really pull the front end up on launch too. i would reccomend them to anyone. and you dont have to pull any carpet up.
Old Apr 25, 2003 | 01:49 PM
  #17
ls1camarogal's Avatar
Originally posted by kevin97z28
I have not installed SFC's, I have talked to several people who have them to get their opinion on them (bolt in and weld in). Seems it really really tightens the car up, but alot of the road "noise" is also transferred throughout the whole car! So i have been reluctant to install these at this point.
Kevin
I just had Kenny Brown SFCs installed on the 19th and it was well worth it! I don't have LCAs yet because I still don't know which to purchase (any help would be greatly appreciated ) but my car had the same problems as all of yours, gettin squirrelly when hitting a minor bump at 65mph, body roll similar to a worn out Galaxy 500. The SFCs and an alignment took care of all of that AND the squeaks I got just from normal driving when the car would flex.
Old Apr 25, 2003 | 09:31 PM
  #18
96Z28TealM6's Avatar
I'm in the same situation as you were...my rear bounces too damn much...kinda brings me back memories of my 2001 Jetta 1.8T...
Old Apr 28, 2003 | 09:38 AM
  #19
chuck's Avatar
I agree with Ken on the shocks. The stock Decarbons are junk right out of the box.
Originally posted by robvas
Solid rear axle = Blows for turning on pavement that's not smooth as glass
While a live axle is not the ideal handling setup, it is not as bad as you make it out to be. IRS suffers camber change as the suspension works, which effectively reduces the contact patch. Also, maybe you can explain how the F-body, which is required to use a restrictor plate to choke the horsepower down, is "the car" to have in SCCA stock class road racing? Other cars in the class, which mostly have IRS, are the BMW M3, Honda S2000, Porsche Boxster S and Mustang Cobra. Here is a link to the results from the Runoffs (national championship) last year: http://www.scca.org/amateur/club_rac...s/t2-race.html
Old Apr 30, 2003 | 11:17 AM
  #20
RacerChuck's Avatar
My car suffered from the same thing. My mechanic found a broken tranny mount. I had it Replaced and the car drove better but still not the way I thought it should.
Then @ the next oil change I had him put it on the lift and check the suspention. Turns out I also had a loose lower control arm.
From the evidence of the wear marks in the mount from it moving all over, we estimated that it probably had been loose since it left the factory.
Anyway, with all the loose and broken parts fixed and replaced, and a new set of Goodyear Eagle F1's, the car is feeling better than it ever had since I bought it new 3 years ago.
RallyRed701/2
Jul 27, 2015 02:55 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
94Form
Jul 17, 2015 10:56 PM
whitehooptie
Jul 12, 2015 06:10 PM
mrwz28
Jul 8, 2015 09:11 PM
