My reverse lights dont work!
Old Aug 7, 2003 | 12:51 PM
LT-14me's Avatar
hello all, i just noticed that my reverse lights do not work when i put the car in reverse. All teh other lights work except for those. And i kinda need them to pass state inspection. Anyclues? I dont havee an ownersmanual so i am kinda **** out of luck on fuses or anything like that. I just bought the car a week ago. It is a 98 Camaro SS M6. Thanks for the help.
Old Aug 7, 2003 | 01:42 PM
Constrictor98TA's Avatar
If its the fuse, just pull the fuse panel off the side of the dashboard by the drivers side door. On the underside of the panel will be a diagram telling you which fuse is what.
If you have an automatic, it could be that the reverse poisiton sensor is off or broken. To see if thats it, have someone stand behind your car while you shift from P all the way to D, and then back. See if it comes on at any other point, such as between P and R, or R and N, or in N. If thats the case, then you need to tear apart the center console and fix it. If you have an M6 or, if the lights dont come on at all, I have no other ideas.
Old Aug 7, 2003 | 01:53 PM
foff667's Avatar
or its also possible that maybe the BULBS are OUT! lol just a thought
lata
Bill
Old Aug 7, 2003 | 05:37 PM
OutlawLS!'s Avatar
True, both my reverse lights blew out at the same time. They were not that old either.
Old Aug 7, 2003 | 09:04 PM
foff667's Avatar
even if one blows out first then the other months later...unless you look or someone else points it out its hard to notice...its like a 5 minute fix if that is the problem though.
lata
Bill
Old Aug 7, 2003 | 11:56 PM
LT-14me's Avatar
Well, i havent been able to check the bulbs cause it rained today and i dont want to get any watter in the assembly. But is there anything else that might be the problem? I mean both of the lights are out. Oh and i have an M6. I looked on the fuse box and it just says tail lights, and the fuse looks ok.
Old Aug 10, 2003 | 11:13 PM
LT-14me's Avatar
Well, i finaly got around to pulling the bulbs and the filaments arnt burnt. I was told that there is a switch on the tranny that allows the lights to go on or not? Is this true?
Old Aug 11, 2003 | 05:35 AM
Kwiksilverz28's Avatar
The switch is in the side of the tranny. There is also the CAGS thing there, so get the new switch and make sure you pull the right one. Easy job. Hardest parts will be jacking the car up and refilling the tranny with any lost fluid...
Old Aug 11, 2003 | 05:49 PM
lastZ's Avatar
it is the switch, i have a 2002 Z mine went after 200 miles, took it into the dealer 10 minutes later i was gone!
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
siguy
Nov 27, 2014 10:07 AM
