Motor Oil
Old Mar 6, 2008 | 05:24 PM
midnightnavyz28's Avatar
Motor Oil
I bought my car new & have ALWAYS used Royal Purple Full Synthetic 10w30 & K&N Performance Gold Oil Filter EVERY 2,500 miles.... what do u guys think of royal purple?....i know a lot of ppl dont like it....but with 69k miles my car runs just like the day i bought her....what do u all use?.......every1 tells me how much better mobil 1 is & that im gonna mess my z28 up using royal.....im just not convinced w/ the way its performed for me
Old Mar 6, 2008 | 10:18 PM
Kraest's Avatar
Retired
All of that is overkill.... from the mega-expensive oil, to the pricey filter to the extremely short oil changes.es
Not to mention that you should be using 0w or 5w30, not 10w30 in the LS1.
Mobil-1 5w30 Synthetic, Mobil-1 Filter, change every 5000 miles.
Old Mar 7, 2008 | 05:25 AM
byrons1502's Avatar
overkill is a great thing. just run the oil a little longer unless it is a track baby. i run the amsoil for 10,000 miles and not the possible 25,000. i like the insurance. still have over 300,000 on two of my daily drivers and they pull trailers(gas motors not diesels). i used to run mobil with no problems but switched to amsoil for the extra hp and gas mileage
Old Mar 7, 2008 | 01:31 PM
AL SS590 M6's Avatar
Moderator
My only gripe against RP is that when I tore the motor down after running it for 2 seasons there was tons or black residue in the pan.
Old Mar 7, 2008 | 01:36 PM
ss.slp.ls1's Avatar
Just use any name brand 5w-30, change it regularly, done. Concern yourself with other aspects of your car besides what fluids you are using.
Old Mar 8, 2008 | 03:23 PM
Chrome383Z's Avatar
I have heard of problems like this from Royal Purple. An oil tech guy I know that is an engineer for Harley Davidson considers it a "snake oil" and highly recommends against it...
Old Mar 8, 2008 | 03:25 PM
Chrome383Z's Avatar
Hell, with that oil/filter combo you could even go 10k and be ok. I'd change every 6mo though. (once a season for most ppl here that garage their cars in the winter).
Although, if i was going to the track alot i'm not sure how often I'd change the oil. That's a good question..?
Old Mar 8, 2008 | 03:26 PM
Chrome383Z's Avatar
Agreed on most brands are ok, but that "fluid" is the only thing providing a "lubricating" film between your crankshaft/rods when you're spinning 6,500+ RPM.
Old Mar 16, 2008 | 03:15 PM
brians96Z's Avatar
I use Pennzoil Platinum Full Syn. 10w30. No problems at all. Everyone always bashes Pennzoil, but there is no truth in it. Like said, prettymuch any name brand oil and you'll be ok.
Old Mar 18, 2008 | 01:00 AM
mikeZ2878's Avatar
I use Mobil 1 10w30
Old Mar 18, 2008 | 01:01 AM
mikeZ2878's Avatar
Old Mar 18, 2008 | 01:08 AM
LastBreedLS1's Avatar
so what is it 10w30 or 5w30. i always here to use of both. i use 10w30 full syn. i was told to use it cause i have over 100k on mine. and 5w30 is to thin. I'm not sure if thats true. any confirmation?no problems yet!!
Old Mar 18, 2008 | 05:35 AM
maverickmk's Avatar
I thought a while ago Mobil 1 touted their oil as 25,000 mile oil (?) I see that is no longer the truth - my problem with that is I think you would want to change the filter in that 25k somewhere
Old Mar 18, 2008 | 08:52 AM
Moderator
The owners manual calls for 5w30 as the standard. It also says that you can use 10w-30 if you never see temps below 40 degrees.
And as far as 5w-30 being thinner than 10w-30 that true but only during start up when the oil is stone cold. The 5w and 10w is the viscosity when cold. The 30 is the viscosity when warm/hot. So they are both the same visc. at running temps.
Old Mar 18, 2008 | 09:28 AM
teke184's Avatar
i use 10w because where i live we've seen <50 about 3 days in the past 5 years.
