which mods next??
which mods next??
What next?....i have a 2000 SS 6 speed that has these mods:
160 t-stat
LS1 motorsports Air Lid
K@N
Free ram air mod
Ported mass air ends
smooth bellow
throttle body bypass
free EGR mod
cutout
what should i do next? i was real disappointed with my first dyno run with these mods, it only went 308 rwhp, and 323TQ...it is also only going 13.7 @106 in the quarter....what mods do you suggest next?...keeping the limited funds in mind.
any help will be greatly appreciated.
160 t-stat
K@N
Free ram air mod
smooth bellow
free EGR mod
cutout
Here is a easy suspension mod.. keeps rear end
from sagging..
http://ls1info.com/article.php?sid=246
from sagging..
Given your 106mph trap speed but your 13.7 ET, I'd say work on traction! A new clutch, drag radials, lower control arm relocaton brackets, and lots of practice driving. With that trap speed you should be running low 13's. You must have crappy 60ft times ~ 2.3 ish???? Practice driving - it's your cheapest mod
More HP and FT-LBS will just make you spin the tires more.
Yea my 60 ft times are in the 2.3 range, an occasional 2.4 which i know is terrible...all my runs to date are on street tires so i think i might borrow a set of drag radials. You guys really think i need a catback exaust?....i already have a exaust cutout, shouldnt that be enough?
I'm assuming you still have stock pipes, so get some mandrel bent 3" pipes to go w/ the cut-out. Short shifter also (or so SS's already come w/ one? I dunno
And yeah, a cam would put out some numbers you should like I'm sure.
)And yeah, a cam would put out some numbers you should like I'm sure.
The Supersucker is a cold air induction kit. Speed inc and LM Performance are just a couple of the sponsors that sell them.
www.lmperformance.com
www.ls1speed.com
www.ls1speed.com
CARiD
Jul 7, 2015 08:19 AM
