Mobil 1 and piston slap??
Old Nov 17, 2004 | 07:47 PM
Briank8811's Avatar
Today i changed my oil from regular to synthetic mobil 1 and for the first time i noticed pistion slap when i started up my car. Just wondering if its my car or other people have noticed it? Also my change oil light came on....what do i do to get that thing to go away? Thanks, Brian Kaiser
Old Nov 17, 2004 | 08:38 PM
Greed4Speed's Avatar
Re: Mobil 1 and piston slap??
Mine will use oil with syn and won't with dino.
Old Nov 18, 2004 | 12:49 AM
lt1camaroman93's Avatar
when i start my car on a cold morrning, the piston slap is VERY loud. I don't know if it is because i use syn oil or not. Once the car warms up it is fine again.
Old Nov 18, 2004 | 01:37 AM
Mike94ZLT1's Avatar
Brian K, is this on your 94 or a different car?
Old Nov 18, 2004 | 04:05 AM
BirchMan98z's Avatar
synthetic oils tend to be a bit thinner, this could possibly contribute to piston slap I suppose.
Old Nov 18, 2004 | 04:49 AM
AL SS590 M6's Avatar
Moderator
I run the same Mobil 1 5w-30 full synth in all 3 gen III motors we have. Two slap when cold, one doesn't. None of them use any oil.
Old Nov 18, 2004 | 07:42 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile Re: Mobil 1 and piston slap??
I live in a warm climate (Southern California) and had a problem with piston slap when using Mobil 1 10W/30. I changed to Royal Purple 10W/30 and the piston slap (at first) was more subdued (sp), now 6K miles later, my piston slap is completly gone.
SteveC
Old Nov 18, 2004 | 04:14 PM
Briank8811's Avatar
Its on my 99 camaro ss. I bought another one sooo yes its and LS1. I was just wondering if anyone noticed this. Btw how can i get rid of this oil change light?
Old Nov 18, 2004 | 05:13 PM
mebanditws6's Avatar
I didn't seem to notice a difference going from 10w30 Valvoline to 0W40 Mobil1 on my car. The colder it is, the louder the slap will be on cold start. I've heard of Amsoil quieting down piston slap in 4.6 Fords though.
Jason
Old Nov 18, 2004 | 06:12 PM
twozs's Avatar
turn the key to the on or run position and hold the trip set down till the change oil light flashes (where is your owners manual!)
Old Nov 18, 2004 | 07:29 PM
96capricemgr's Avatar
the 30wt. M1s are thinner than other brands 30wts. this is not a synthetic thing but rather a M1 thing. Try the 0w-40 if you insist on M1.
Old Nov 18, 2004 | 10:08 PM
MISOMWS6's Avatar
I have always used M1 and always had piston slap so I can't say if it causes PS. I usually get the 5qt jug of M1 10w-30 and a qt of 15w-50 and pour in the 5qts of 10-30 in and 1/2qt of the 15-50 because it uses a little oil, so I use a little of the 15-50b to help a little
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
Sep 18, 2015 03:46 PM
95craz28
11
Sep 12, 2015 07:47 AM
92_RS_305
Sep 8, 2015 07:47 PM
