miss fire and i need help
Old May 22, 2007 | 09:31 AM
camarokidSS420's Avatar
i jus bought a 98 trans am with a 383 stroker in it and its got a custom bult cam and i don kno the duration but i hooked it up to a scantool and its misfiring at idle but when i drive its fine b/c i culd tell if it was because it runs strong but the check engine lights on and i need to pass emissions and i thought it might be the TPS and was wondering what parts i shuld start throwin at it to fix the problem
Old May 23, 2007 | 06:18 AM
AL SS590 M6's Avatar
Moderator
Is it showing multiple random misfires at normal driving speeds?
If it's just happening at idle I'd suspect the computer calibration (tune).
Clean your MAF and IAC to see if that helps.
Old May 23, 2007 | 05:32 PM
today i was drvin it and when i come to a stop and the rpms go down the car cuts out on me or itll drop to like 500 then go up to 1000 about 3 times then remain steady at 1000 rpm but after i give it gas it wants to die on my when the rpms go back to idle
Old May 23, 2007 | 09:52 PM
Kraest's Avatar
Retired
Old May 24, 2007 | 10:46 AM
smithtim's Avatar
agree with AL as it's probably something with the computer tune... but it couldn't hurt to pull/swap the plugs if they are kind of old, as their color tells alot
Old May 25, 2007 | 07:35 AM
lneemup's Avatar
Depending on how big your cam is you're gonna have misfire codes. My car always has them.You can watch it misfire at idle. Thats the nature of the beast.
BTW good luck with the emission's!!!
KYWes
Jun 14, 2022 06:52 AM
techstar
Aug 6, 2015 11:20 AM
BMX Dad
Aug 3, 2015 09:15 AM
BMX Dad
Jul 27, 2015 02:39 PM
RUNMYTA
Jul 15, 2015 07:50 PM
