Which master Cylinder, Ram, McCleod, Stock
Old May 15, 2003 | 07:40 AM
sweet98ss's Avatar
I have a 1998 camaro ss with the m6. My clutch pedal is starting to stick to the floor so I know I know I am going to need the slave cylinder. I am planning on getting the gm updated unit. The question I have is which master cylinder. I know ls1speed sells the updated gm slave and master cylinder for $250. I want to know your opinions on the McCleod adjustable master cylinder and the ram adjustable master cylinder. I am going to get the spec stage II clutch. I just want the best master cylinder which will not give me any problems. I wasnt sure if the updated gm master cylinder will be enough for the spec stage II clutch.
Any one know where the cheapest place is to get this stuff?
I know east side performance and dyno has a sale on clutches.
thanks
Old May 15, 2003 | 08:12 AM
CPFarhood's Avatar
Re: Which master Cylinder, Ram, McCleod, Stock
thanks
I've heard don't waste your money on an adjustable. Also i have a 98 and i wasn't even planning on replacing the master, just the slave.
Old May 15, 2003 | 08:21 AM
sweet98ss's Avatar
Does your pedal stick to the floor......mine does.........I just dont want to have any problems with the pedal sticking to the floor.....maybe screwing up my new clutch that I just spent a ton of money on.......do or did you have any problems with your pedal sticking.........what clutch are you running..
Old May 15, 2003 | 09:04 AM
CPFarhood's Avatar
Stock clutch at 65k it has stuck to the floor only once on me that i can remember. The disc is bad though and the clutch doesn't disengage as fast as it should (another slave cylinder problem i've been told).
Old May 15, 2003 | 11:59 AM
sweet98ss's Avatar
ttt
ttt
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
siguy
Nov 27, 2014 10:07 AM
