Which master Cylinder, Ram, McCleod, Stock
I have a 1998 camaro ss with the m6. My clutch pedal is starting to stick to the floor so I know I know I am going to need the slave cylinder. I am planning on getting the gm updated unit. The question I have is which master cylinder. I know ls1speed sells the updated gm slave and master cylinder for $250. I want to know your opinions on the McCleod adjustable master cylinder and the ram adjustable master cylinder. I am going to get the spec stage II clutch. I just want the best master cylinder which will not give me any problems. I wasnt sure if the updated gm master cylinder will be enough for the spec stage II clutch.
Any one know where the cheapest place is to get this stuff?
I know east side performance and dyno has a sale on clutches.
thanks
thanks
Re: Which master Cylinder, Ram, McCleod, Stock
thanks
thanks
Does your pedal stick to the floor......mine does.........I just dont want to have any problems with the pedal sticking to the floor.....maybe screwing up my new clutch that I just spent a ton of money on.......do or did you have any problems with your pedal sticking.........what clutch are you running..
stockssn2o
May 25, 2015 08:54 AM
