manual windows
Old Dec 21, 2003 | 06:50 PM
chpmnsws6's Avatar
manual windows
how hard would it be to put em in? i have an 00 ws6 and the windows are getting slow going up and down
Old Dec 21, 2003 | 07:03 PM
99blackSS's Avatar
You try greasing the tracks already?
Old Dec 21, 2003 | 07:57 PM
chpmnsws6's Avatar
the dealer put new ones en when i got the car (10 months ago) and i like the light weight thing
Old Dec 21, 2003 | 08:00 PM
joSShua's Avatar
Please describe how to do this. Preventive maintence is always something I like to do to my SS. I have removed the inside door panels before. Thanks-
Old Dec 21, 2003 | 08:21 PM
99blackSS's Avatar
I wouldn't bother with it unless your windows are starting to slow down, but it definitely won't hurt it. The door panels come off and you reach in there and put grease on the tracks the windows travel up and down on. That's about as descriptive as I can be without showing where the tracks are, but you'll see them.
Old Dec 22, 2003 | 07:11 AM
Eric02WS6's Avatar
I recently changed mine. It probably took 2 hours for both window motors. The toughest part was taking everything off the door and finding the rivets. You can find step by step instructions on the internet that will help you. I definetly recommend changing them yourself if it needs to be done...shops will rape you on the price of changing them. Good Luck!
Old Dec 22, 2003 | 10:16 AM
Jilly's Avatar
Here's how to change the window motor.
Old Dec 22, 2003 | 10:47 AM
psychocabbage's Avatar
If I read it correctly though, he is wanting to change to manual windows.. Not sure how that would be done really.. but is that what you were asking? I have manual windows on mine.. hehe
Old Dec 22, 2003 | 01:42 PM
Jilly's Avatar
Aaaah, ok.
Why the hell would you want to do that?
Old Dec 22, 2003 | 03:17 PM
chpmnsws6's Avatar
Originally posted by Jilly
Aaaah, ok.
because they are lighter and the power windows are weak! i've yet to see a manual window give out. my ws6 is a pig and needs to be alil bit lighter
Old Dec 22, 2003 | 03:31 PM
Jilly's Avatar
Is there really that much of a difference? How much do the power windows weigh?
Old Dec 22, 2003 | 03:48 PM
chpmnsws6's Avatar
that lil bit less weight means i can go eat more and it won't gain any
Old Dec 22, 2003 | 04:10 PM
Jilly's Avatar
I was gonna say if there's not that much of a difference, quit eating so much.
Old Dec 22, 2003 | 04:21 PM
chpmnsws6's Avatar
yea right!
<- teenager
BTW- nice car, ur not to bad urself
Old Dec 22, 2003 | 05:36 PM
Jon98's Avatar
well, i went from manual windows to power windows. so you will have to do what i did, but in reverse heh
what i did was get the entire unit as a whole (power window motor unit/regulator) and i took out the manual window crank assembly/regulator all as one peice and just replaced it with the power assembly.
if i was going to do it, i would get the entire assembly and swap it entirely out. i do not think the manual assembly is that much lighter then the power one. You will also need to drill holes in your door panel to accomidate the crank. (drill out all the rivits to get it out, take it off its track, etc etc, then getting it back on its track perfectly, lining it up so it the window seals properly, before re-riviting it.) once you start taking it apart, you will see what needs to be done.
the entire process is a HUGE pain, since your working near blind (cept for using a mirror) reaching in through the tiny access panels. you will need 2 people so the window doesn't come slamming down. make your life easier, just replace the motor using shoeboxs faq
Jon
