Manifold for CNC-Ported LS2 Cylinder Head
Old Nov 20, 2007 | 07:23 AM
  #16
AL SS590 M6's Avatar
Moderator
Originally Posted by Mike94ZLT1
They will work just fine. It is the larger 4.065" LS3 / L92 bore heads that will not fit.
Correct
Old Nov 21, 2007 | 05:05 AM
  #17
rskrause's Avatar
Moderator
Only the LQ9 came with the 317 heads, the LQ4 heads were different. There was a SWEET post on the 317 heads that someone recently deleted. Too bad, it was funny. The 317 is an LS6 port design with the 72 cc chambers as turd already posted. You would be far safer using those heads on a stock bottom end, but there are a few things (primarily rod bolts) I would look at changing if I were to go that route. You can pick up a good budget shortblock with forged rods, pistons, and ARP hardware for right around $3000, if you want it to last that would be the way to go.
Know the part number or casting number for those 317 heads? We are going to try this with a stock shortblock.
Rich
Old Nov 24, 2007 | 12:22 PM
  #18
SStrokerAce's Avatar
Rich,
I will have to look in the shop what that PN is, but the 317 casting is found on all the Iron block 6.0L motors (LQ4 and LQ9)
With just a valve job you can pick up about 30cfm on the intakes and that's a cheap upgrade on a forced induction motor. Just had a set leave the shop for a STS Turbo 408 that's going in a truck.
The CNC ported LS6 heads are ok pieces, ports are huge and can easily be woken up with the correct valve job. They are around 305cfm out of the box from GM and that can be taken up to around 320cfm. They really scream for a larger valve and with that they can move more wind. Either way for the money you can get a better head.
Bret
Old Nov 24, 2007 | 05:51 PM
  #19
rskrause's Avatar
Moderator
Originally Posted by SStrokerAce
Rich,
Bret
Bret: thanks!
Rich
oldschool
Feb 9, 2016 09:21 PM
Noer
Feb 28, 2015 11:29 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Elcojoe
Nov 17, 2014 10:27 PM
