maf 2002 z
Old Feb 19, 2004 | 01:12 AM
Friscoz28's Avatar
From: looking at thick girls in san francisco in my camaro
maf 2002 z
i was wonderin wats the difference from the 75mm and 85mm mass airflow sensor....and i was wondering if the slp brand is as good as the granatelli brand...i look on texas speed .com
Old Feb 19, 2004 | 06:59 AM
teke184's Avatar
um...10mm wider diameter
that is to allow greater flow with less restriction.
as for which one is better...6 of one half dozen of the other
Old Feb 19, 2004 | 09:58 AM
V6toZ28's Avatar
Keep in mind the MAF is a measuring device and the PCM is calibrated to read it's inputs ... change the MAF and the inputs are no longer accurate and the PCM can no longer make accurate AF/R adjustments ... I lost power on the dyno with every AM MAF I tried ... upwards of 23 rwhp in one case ...
Old Feb 19, 2004 | 01:30 PM
Friscoz28's Avatar
so i shouldnt put a maf?
Old Feb 19, 2004 | 01:35 PM
Aklaim's Avatar
The stock maf is not a restriction. It is capable of well over 500hp. There are lots of big power motors using the stock maf.
Old Feb 19, 2004 | 01:44 PM
mullettour's Avatar
Will it hurt or help to descreen the maf?
Old Feb 19, 2004 | 01:48 PM
Aklaim's Avatar
Leave the screen on. I breaks up the turbulence of the air flow coming into the engine. Have you ever taken a screen off of a faucet and seen how crappy the water comes out? The same principle applies here.
Old Feb 19, 2004 | 02:46 PM
Friscoz28's Avatar
is there a difference between the slp maf and the granatelli brand?
Old Feb 19, 2004 | 09:38 PM
V6toZ28's Avatar
One more time ... the MAF is a measuring device and the PCM is calibrated to read it's inputs ... change the MAF and the inputs are no longer accurate and the PCM can no longer make accurate AF/R adjustments ...
Specifically, the PCM is calibrated to the stock MAF ...
Old Feb 21, 2004 | 04:05 PM
rixz28's Avatar
Doesn't the computer "learn" about the new MAF and make adjustments? I put in a SLP 85mm MAF with the new lid and noticed a big SOTP difference. SLP was $175, Granatelli is like $300 or something like that.
Old Feb 21, 2004 | 06:10 PM
Chopstix's Avatar
The SLP MAF is the same MAF put on 6.0L vehicles but they are recalibrated to work with the factory ECU
Old Feb 22, 2004 | 12:54 AM
AL SS590 M6's Avatar
Moderator
Seat of the pants is absolutely the worst dyno ever built.
Take it to the track with the stock MAF then change it to the new one. Back to back runs.
Aftermarket MAFs are the biggest waste of money on a stock or near stock LS1 that anyone ever came up with. Heck you might as well go out and buy a Tornado.
Look at my sig. That's with a stock motor and a stock MAF.
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
