M6 Technical Service Bulletin?
Old Jul 14, 2003 | 12:55 PM
rjarrardZ28's Avatar
Question M6 Technical Service Bulletin?
In a earlier thread, a member made reference to a Technical Serivce Bulletin issued about bad syncros in the M6 Tranny. Does anyone know where this TSB may be, and where I can find it. I surfed the internet thismorning, but to no avail. My local dealership keeps getting rid of me when I take the car in for service, and I would really like to have a copy this TSB so I can use it for leverage. Thanks ahead of time!
Old Jul 14, 2003 | 01:16 PM
NEWBIE T/A's Avatar
Talking Get it while the getting is good !
This is a great site, but it is not always up !
http://web.archive.org/web/200112181...regg/gmsi.html
I skimmed for a '01 M6 bulletin, but did not see one.
Perhaps I missed it.
Good Luck !
Britt
Old Jul 14, 2003 | 01:18 PM
2001NBMZ28's Avatar
Start with www.alldata.com/recalls/index.html to get the TSB#/title then try a web search.
Old Jul 14, 2003 | 04:14 PM
PJS TOY's Avatar
Reply to you with info in earlier thread.
PJ
Old Jul 14, 2003 | 05:23 PM
Demon SS's Avatar
try this
http://web.archive.org/web/200111081...7-29-003A.html
Old Jul 21, 2003 | 12:47 PM
6spdz28's Avatar
Demon by that bulletin. if i take my SS to the locasl dealer they will fix it for free. or am i wrong
Old Jul 21, 2003 | 01:58 PM
NAKSTOCKZ28's Avatar
I had the same problem and it just got worse in worse to the point where it would spit it out of third gear 97% of the time. I have an 2001 and i guess that link is only talking about the 99-00 models. I just got my car serviced and it seemed to be fixed but it still spits it out at low RPMs. Lets say if skip shift is activated and i decide to go to 3rd instead of 4th, there is a pretty good chance ill get rejected from 3rd gear. 4th gear can take the below idle RPMs when skip shift is activated but 3rd cant eventhough the RPM would be higher in 3rd. I guess im going to have to go back to get it fixed again and this will be my 3rd time. I was wondering if someone else had this problem and if anyone knew what exactly is causing this. The link above seemed to describe my problem pertty accuratley so i think imma print it out before i go to the dealership next time.
thanks
Old Jul 21, 2003 | 04:42 PM
mr_muff's Avatar
with a tsb, lets say my car is not under warrany anymore, but this problem happens. now since they made the tsb and know about it, would i still have to pay for their mistake?
Old Jul 21, 2003 | 09:03 PM
2002Z28SSConv's Avatar
If you took it in for service before the warranty expired for the same problem and they could not diagnose/fix it, you might be able to get them to cover it. However, a TSB is just a quick way for common problems to be diagnosed at the dealership. It doesn't mean that every (or even most) cars will have the problem. It's not a recall. So if you first complain about the problem after the warranty has expired you'll get no "freebie service coupon" by wavnig a TSB at them.
Old Jul 21, 2003 | 10:52 PM
mr_muff's Avatar
damn, hopefully non of these tsb's happen to me
Old Jul 21, 2003 | 11:20 PM
AL SS590 M6's Avatar
Moderator
I'd make that a 100% chance.
Keep in mind that "skip shift" blocks 2nd and 3rd when activated not just second. I forces you to shift from 1st to 4th.
Put a module or a resistor in and get rid of that stupid skip shift.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
plattted
9
Sep 20, 2015 11:23 AM
