LT Headers, Noise, Slow
Old Mar 19, 2006 | 10:41 AM
02BlackSS's Avatar
Question LT Headers, Noise, Slow
I have an 02 SS and last week I put in some Pacesetter LT's with there off road Y-pipe and now the car feels like it isn't pulling as hard as it did before the install. Is it common to lose a little down low with the LT's? Also I don't know if its because I am running no cats but they sound noisy, not raspy but just noisy everything is tight, but it just sounds like things are banging around under the car. Just curious if anyone else experienced what I am talking about with there car.
Old Mar 19, 2006 | 11:42 AM
JadedZ28's Avatar
Re: LT Headers, Noise, Slow
the car will be louder if u delete the cats, and have u had a tune? if not thats probably y ur experiencing power loss
Old Mar 19, 2006 | 12:56 PM
00cls1camaross's Avatar
yeah your motor wont feel at torquey with the lts because LS1s like backpresure... but you should feel the gain in the upper rpms
Old Mar 19, 2006 | 01:18 PM
mook99TA's Avatar
The banging noise may be from when your engine torques up the headers don't have enough clearance so they will knock a little bit but poly motor mounts will cure the banging.
Old Mar 19, 2006 | 01:56 PM
02BlackSS's Avatar
Ok, so I need a tune and some poly mounts. Thanks guys..
Old Mar 19, 2006 | 06:02 PM
teke184's Avatar
well...you don't neccessarily NEED either of those. look to see if the headers are hitting anything, or if the ypipe is.
you'll know it if they are hitting...it will be like someone is pounding on the underside of the car really fast. and it should go away when you are idling or just maintaining a speed...ie.. not putting much strain on the motor.
there should still be a noticable power gain even without the tune. lots of dynos have shown a solid 15hp untuned from headers.
Old Mar 19, 2006 | 06:56 PM
wdtiger's Avatar
No engine LIKES backpressure, btw.
Old Mar 19, 2006 | 09:15 PM
umm the ls1 seems to... it gives it more torque when you have backpressure
Old Mar 19, 2006 | 09:56 PM
AL SS590 M6's Avatar
Moderator
Old wives tale. Not true at all.
Old Mar 19, 2006 | 11:11 PM
GhostZ28's Avatar
You're telling me I'll have more torque with shorty headers and 2.5" exhaust and a stock muffler? I'm not buying it
edit: not trying to be an a$$, just stating an example
Old Mar 19, 2006 | 11:14 PM
i guess you all are right, but i remember i was talking to kraest and i asked him why his torque numbers were kinda low and he said because he had 1 7/8inch primaries which means less backpreasure
i assumed this to be true, my B
and i honestly have no personal expieience, my bad
beltrunner
May 17, 2015 10:18 PM
blkWidow
Apr 21, 2015 01:56 PM
BigWil
Mar 29, 2015 12:24 PM
Fatdog2
Feb 12, 2015 12:24 PM
squarehead
Nov 21, 2014 08:02 PM
