LS6 Intake Manifold on late 2002's
Old Oct 18, 2006 | 10:53 AM
NASCR46's Avatar
I have heard the cars delivered late in the model year (ours was delivered July 4, 2002) had LS6 intake manifolds.Is this true ?How can you tell?What are the advantages if any? I'm thinking Increased horse power? Thanks
Old Oct 18, 2006 | 11:10 AM
Nostang 96z's Avatar
Re: LS6 Intake Manifold on late 2002's
All 01-02 Ls1's came with the LS6 intake. Some later model 02's came with the LS6 block though.
Old Oct 18, 2006 | 12:01 PM
NASCR46's Avatar
Is this good and how can I tell?
Old Oct 18, 2006 | 12:34 PM
SlowTA367's Avatar
Yes this is good. The LS6 makes more power and has no egr. If you look at the intake, right behind the throttle body, it will either be smooth or it will have some emissions stuff (egr?). If it is smooth it's an LS6.
Old Oct 19, 2006 | 12:28 PM
darrens99formul's Avatar
You definately have the LS6 intake. Like previously mentioned, they came standard in every 2001 & 2002 F-body. As for the ls6 block I'm not sure how to tell if you have it.
But I wouldn't go looking for it either. It'll gain you nothing power wise and by the time a stronger block is needed you've all ready replaced it with a 402, 408 or 427 anyway
Old Oct 19, 2006 | 08:03 PM
pg318's Avatar
Here's an article on teh development of the LS6, most of the improvements to the LS1 came as a result of common parts developed for the LS6. Here's how to tell if you've got an 'LS6' block, these became the standard block for LS1 and LS6 in 2003, but were fed in gradually from late '01 and appeared in LS1 builds I guess as overspill. Nice to have, but not worth getting if you don't. I found a quote from John Juriga a few years ago saying that the reduction in parasitic loss was worth a couple of hp, but the change was made mostly to avoid oil whipping and starvation from failure to flow back. Can't find it now.
Old Oct 25, 2006 | 01:45 PM
JeffSTAR's Avatar
Can anyone confirm that the 02 F-car also had the larger LS6 MAF/TB combo?
Is this true?
Old Oct 25, 2006 | 02:08 PM
Negative. The 02's and 01's were identical for LS6 intake and 78MM throttle body.
Here is a real good breakdown of the differences between the years:
http://www.ls1tech.com/forums/showpo...80&postcount=2
Old Oct 25, 2006 | 02:49 PM
JeffSTAR's Avatar
Wow thanks, looks like I have a Z06 style clutch. Maybe it will last more then 1 hour with my TFS heads/cam combo
Old Oct 25, 2006 | 04:17 PM
2002ss's Avatar
I hope so for you. My A4 gave out right away and the rear gear gave out within 5000 miles
Old Oct 25, 2006 | 06:55 PM
GusarskiSS's Avatar
Are the '00 motors good compared to the differences in '01's? Because I'm looking at buying a '00 Camaro SS or a '01 TA WS6, and I can't decide which one to buy.
Old Oct 25, 2006 | 09:03 PM
Greed4Speed's Avatar
Buy which ever you get the better deal on. Once you mod it won't matter.
Old Oct 26, 2006 | 12:35 AM
GusarskiSS's Avatar
How about if I was planning on keeping it stock?
Old Oct 26, 2006 | 07:46 AM
teke184's Avatar
honestly they are nearly identical
the later years got the intake, but a smaller cam
but how could you leave it stock??
j/k
even basic bolt ons will have them equal in the end, and even more so if you dive into the motor
Old Oct 26, 2006 | 08:18 AM
Then I would get the 01. You'll get the ls6 intake manifold and probably a few less miles. That is of course if you have no preference on appearance. I myself LOVE the WS6 look
