LS6 intake
Old Apr 19, 2005 | 03:34 PM
  #16
99Blackt/a's Avatar
Re: LS6 intake
How big of a weather fluctuation was there was the relative humidity up, was it warmer, was the track prepped properly, there are so many variables involved it could be just that
Old Apr 19, 2005 | 07:25 PM
  #17
Greed4Speed's Avatar
Re: LS6 intake
Originally Posted by calee
I was told that the screen are used in trucks where the air approaches the MAF from the side,and the screen is used to straighten the air flow so it will not get false readings.In the corvette and camaro/firebird thay have straight intakes and don't need them.I know the '02 and up corvette doesn't have a screen in the MAF from GM.What would be the down side of removeing the screen on my '00? My 1st post i said a 85mm TB, I ment to say a 80mm.I think the LS6 intake is the one for me.how much can i get one for used? what do you think about the ele. water pump? money/HP. and last the exhaust,what is the worst part, manifolds or cats? thanks for your help and time, Cale
You won't see any gains from descreening, so why mess with it? You also have to realize that the non-screened MAFS are probably calibrated for that.
I wouldn't mess with an electric pump either. I seriously doubt it would last long under daily driving conditions and then the gains would be minimal as stated before.
Old Apr 19, 2005 | 08:57 PM
  #18
calee's Avatar
Re: LS6 intake
If i do get a LS6 intake,can i use my 75mm TB? or do you have to use the 80mm TB. Also the MAF 75mm or 80mm? Thanks for all the help.
Old Apr 19, 2005 | 09:02 PM
  #19
346CItofreedom's Avatar
Re: LS6 intake
I'd never take the screen off the MAF. When i picked up my car, the bracket around the stock air filter was warped or something, and air was blowing by the filter. I pulled a bunch of sticks and leaves and other lovely crap off the MAF screen.
Old Apr 19, 2005 | 09:10 PM
  #20
teke184's Avatar
Re: LS6 intake
the LS6 intake was designed for the same TB as the standard LS1 intake...so it's fine.
stock maf is 75mm
Old Apr 19, 2005 | 09:32 PM
  #21
calee's Avatar
Re: LS6 intake
Thanks, I have one more for you,exhaust: the manifolds , cats, or the muffler. what is the best way to go? if you had to pick one of them to be replaced.
Old Apr 19, 2005 | 09:47 PM
  #22
99Blackt/a's Avatar
Re: LS6 intake
Youll want a cat back of some form and headers as far as cats are concearned it depends on wether or not you can get away with no cats in your area. Headers and true duals would be your best route performance wise but what you can afford comes into play....
Old Apr 19, 2005 | 10:06 PM
  #23
calee's Avatar
Re: LS6 intake
thanks for your help.I am looking at the Jeg's mag. and their is 14+ pages on exhaust.next year thay will have pollution controll for cars in my town.I live in southeast NC. I wish at times i would have got a '67-'69 w/396,but i like my '00 SS.maybe one day i can have both. Thanks, Cale
Old Apr 20, 2005 | 08:19 AM
  #24
'88Saleen's Avatar
Re: LS6 intake
You may be in luck. Alot of states that have emmisions testing for OBDII cars they just plug a scanner into the diagnostic port and check for codes.If you run a off road Y pipe and you add the O2 sims the cpu wont throw any codes. The only way you could fail is if they put the car on a lift and see theres no cats.
I have a few friends that used to work at garages that did inspections and they told me.If a car had wheels that you could see the rotors good(to check brakes) they dont bother putting the car on the lift then they just scan it for codes and check the lights and your good to go.
I would'nt bring it to a Gm dealer or anything like that (places like that go through your car completely hoping to find somthing wrong so you can pay them to fix it) but find a smaller garage that does inspections.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
R@mpage
Apr 20, 2015 10:02 AM
99TransAmWS6
Mar 22, 2015 11:00 PM
birdblack
Dec 30, 2014 06:59 PM
hotrodyou1
Dec 20, 2014 10:05 PM
