ls6 heads
Old Feb 17, 2006 | 08:59 PM
ls1650's Avatar
ls6 heads
hey guys i was just wondoring about how much horsepower and torque i would be at if i got a new set of ls6 heads?
Old Feb 17, 2006 | 09:03 PM
Greed4Speed's Avatar
Re: ls6 heads
not that much with the stock cam
Old Feb 17, 2006 | 09:53 PM
JakeRobb's Avatar
Super Moderator
Re: ls6 heads
With your mods, you'd see some gains. 20hp? That's probably high. Ported LS6 heads, along with a hotter cam, and you could see a lot more.
Old Feb 21, 2006 | 09:09 PM
LarrieuY2KSS's Avatar
Re: ls6 heads
when you say "a lot more" how much is that? aslo what cam would prove "a lot more" power with ported LS6 heads?
Old Feb 21, 2006 | 09:14 PM
myslowcamaro's Avatar
Re: ls6 heads
with a 224/224 type cam, or one in my sig, h/c 90rwhp or better can be achieved. other heads considerations should be afr 205 or 215, prc stage 2.5, 2.5 (5.3l) or stage 3
Old Feb 21, 2006 | 09:53 PM
goldwing22mn's Avatar
Re: ls6 heads
im going to sound dumb too, but what is Brown Drawers?
Old Feb 21, 2006 | 10:58 PM
00cls1camaross's Avatar
Re: ls6 heads
off kraests sig? it means that since he is going to have a 470+ rwhp car, when he drives it he is going to take a poo poo in his pants. Since, **** is brown, you will need brown pants so no one can see his accident!
Old Feb 22, 2006 | 05:33 AM
Re: ls6 heads
if thats the case, now i really do feel dumb....lol
Old Feb 22, 2006 | 06:32 AM
teke184's Avatar
Re: ls6 heads
stock ls6 heads on a stock cam....10-15hp...maybe.
for cams, what kind of power levels are you looking for? with the LS1 you can easily make good power with just a cam swap. how much drivability are you willing to sacrifice?
Old Feb 22, 2006 | 10:18 AM
Re: ls6 heads
Since you can get PRC ported LS6 heads for under $900, why run stock LS6 heads?
Old Feb 22, 2006 | 10:59 AM
Re: ls6 heads
what is the difference between stage 1.5, 2.5, 3 heads offereed by PRC?
Old Feb 22, 2006 | 11:11 AM
Re: ls6 heads
valve and port size
Old Feb 22, 2006 | 11:33 AM
Re: ls6 heads
performance wise what does that equal up to at the rear wheel?
Old Feb 22, 2006 | 03:10 PM
Re: ls6 heads
If you have a large cam you'd need larger ports and valves.
Stock or smaller cam smaller valves and ports.
Performance wise? Depends on what you have and what you decide to go with. Go large heads on a stock cam and it'll kill your low RPM and not do a whole lot for you up top either.
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
birdblack
Dec 30, 2014 06:59 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
