Ls6?
Old Jun 6, 2005 | 01:00 AM
MarlboroMan's Avatar
Ls6?
ok guys, i know it may sound retarded, but whats the exact difference between an LS6 and LS1? like what makes it so different?
Old Jun 6, 2005 | 06:50 AM
teke184's Avatar
Re: Ls6?
minor differences in the block, different cam and heads
Old Jun 6, 2005 | 11:33 AM
anasazi's Avatar
Re: Ls6?
oil pump
cam
heads
intake manifold until the later years
the block had minor differences, none of which affected horsepower.
Old Jun 6, 2005 | 04:38 PM
Greed4Speed's Avatar
Re: Ls6?
clutch also
Old Jun 6, 2005 | 05:38 PM
psychocabbage's Avatar
Re: Ls6?
Actually... the block on the LS6 has larger windows to make bay to bay breathing better. Does that affect horsepower? Yes.
(Source: GM Engineer in a video explaining the LS6)
Old Jun 6, 2005 | 06:11 PM
Re: Ls6?
you can get an ls1 converted into an ls6, right? if so, how much does that usually run?(cost wise)
Old Jun 6, 2005 | 07:30 PM
00ls1's Avatar
Re: Ls6?
for the cost of ls6 parts to make your ls1 a stock ls6 you could make your ls1 make alot more power for less money..
Old Jun 6, 2005 | 11:37 PM
Re: Ls6?
what do yall recommend?
Old Jun 6, 2005 | 11:42 PM
Knowklew's Avatar
Re: Ls6?
pick a heads/cam combo that suits your needs. i would suggest going to an LS1 speed shop or a shop that knows what they are talking about and tell them what your goals are . Depending on what you want to do will determine your setup.
Drag only
Street/strip
Daily Driver
how many miles do you plan on driving a year?
do you care about gas mileage?
figure out your overall goal, then go from there.
Old Jun 7, 2005 | 07:38 AM
teke184's Avatar
Re: Ls6?
hmm...TR has a new cam/heads package
they say almost 400rwhp with stock exhaust. interesting....
Old Jun 7, 2005 | 09:55 AM
SSpdDmon's Avatar
Re: Ls6?
That's f***ing sweet! That would save me $800 for headers and tuning should be a breeze if it has nearly stock properties. Tweak a table here or there and get the AFR dialed in with a WB...395rwhp + stall + sticky tires = low12's~high11's.
JJOHNROE
Parts Wanted
Oct 23, 2015 02:03 PM
speedracer1280
Sep 8, 2015 06:12 AM
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
hotrodyou1
Dec 20, 2014 10:05 PM
