LS2 w/ APS Twin Turbo- Twin Intercooled Kit
Old May 1, 2008 | 09:52 AM
Thunder-ZTA_'s Avatar
Does anyone know if an LS2 with the APS twin turbo kit is able to fit into a 2002 Z28 that previously had an LS1 in it?
Old May 1, 2008 | 12:42 PM
Gripenfelter's Avatar
Yes it will.
Reason I know is because I'm also looking at doing this.
Old May 9, 2008 | 12:49 AM
ah ok, well ty for the confirm. im pritty sure there will be some thing that will be needing changed out as well correct. such as a stronger tranny, reinforce the frame, etc?
Old May 10, 2008 | 01:39 PM
You need an aftermarket K-member like UMI or BMR.
Old May 15, 2008 | 01:56 PM
Just a K-member and everything will run fine? I thought more would be needed to make it run
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
305fan
Jun 27, 2002 09:44 AM
