LS1 Valve tap
Old Aug 4, 2006 | 07:31 AM
dtowncats's Avatar
LS1 Valve tap
I am looking at a 98 Z28 for a friend who is in Iraq right now. The seller told me it has a slight valve tap though. What are your opinions on buying this and what causes a valve to tap? I know the valve covers need to come off and normally something needs to be adjusted but I am not sure what it is. Thanks guys!!!
Old Aug 4, 2006 | 08:22 AM
AL SS590 M6's Avatar
Moderator
Re: LS1 Valve tap
These engines have non-adjustable rockers. It's probably a bent pushrod which "could" mean abuse or just a miss shift.
To be safe you should take it to a shop and pay for a detailed inspection.
Old Aug 4, 2006 | 10:13 AM
dtowncats's Avatar
Re: LS1 Valve tap
Ok thanks... I will probably just stay away from the car then. He was choosing between that and a 97 SS 30th ann.
Old Aug 9, 2006 | 11:10 PM
GhostZ28's Avatar
Re: LS1 Valve tap
Well in that case i'd suggest the LS1 powered car.
Old Aug 10, 2006 | 09:03 PM
DLindlZ28's Avatar
Re: LS1 Valve tap
yeah i had a lt1 camaro and never again will i every buy one after one problem u get them all then i got a ta ls1 and i love it the lt1 sounds better though
kksi
Feb 16, 2015 06:49 PM
Jazsun
Dec 29, 2014 12:14 PM
