Ls1 Top Speed?
Originally posted by Dr.Mudge
Whats "funny" about top speed, is it is more dependant on aero and horsepower, than weight
) then weight becomes a factor again.some ppl are just plain crazy.
jay
san francisco
I dont plan on any 600 MPH runs, so I am not going to bother investigating
One problem to deal with is downforce, which inevitably means your going to add some drag, although probably not much if done right. Next thing is just pure horsepower, it takes maybe 100 HP for a car to do a little over 100, and it could take maybe 550+ HP or so to hit 200. Dont forget some good shocks to boot, I know my Koni DAs rock up to 150, but have never gone past that yet...
Those salt flat guys run skinnies too, and I want grip, but that'll cost you a little speed.
mine came with the goodyear rsa'a and I've hit the govenor at least 10 or 15 times -- but i don't know exactly how fast I was going b/c the speedometer was past the 155mph that my stock speedo shows
hey, i dont know how in the hell you guys are going this fast. My car at full throttle in fifth gear towards redline is like 135-140, then i have to shift to sixth, which cant pull itself out of its own urine puddle
. So you guys with Standard trannys, how are you doing it?
Something is up with your car if your redline in 5th is 135??? With 3.42s and a stock tire size, redline in 5th is 181 MPH.
I assume you must be running 4.56s? In which case, when you go to 6th your out of your powerband, and you wont have the HP to pull 201 MPH.
http://www.f-body.org/gears/
Originally posted by CODY BEHNKE
! IF ! it could go 181
Also, the guy said that he's at 135 to 140 mph towards redline..not necessarily at redline. He should be close to 5000 rpm by that speed, right? That's close enough to redline to remember..especially if you don't go there much.
My '99 is alot faster though
. Only hit 130 so far, but wind noise from driver window gets pretty loud. Sounds like this window pulls away from the body, anyone else have this?
Originally posted by 99BlackZ28T56
With 150hp stock on my '86 TA 5spd with the 5.0 LO(carb) 140k mi I hit 140+ many times. Only mod was a 3in. flowmaster catback.
Remember that the 5.0 Fox Body could not break into the 150 MPH range until they duct taped the front, and that was an over 200 HP car.
