Ls1 Top Speed?
i have hit the 162 mph top speed limiter more than a few times in my '99 z/28 (a4, 3.23) with just a lid, maf, fra, and cat-back. it ran into the limiter pretty hard, so i'm sure that there was more to be had. i just had the pcm reprogrammed and the limiter has basically been disabled by setting it to 255 mph. i'm guessing my car will do close to 170. i'm currently working on upgrading my brakes.
jay
san francisco
jay
san francisco
Originally posted by stik6shift98
if your tires were f1 from the factory then your limiter is around 158...if it cam with gsc or gs or enything other then f1s then top speed limiter is at 115
jay
san francisco
Originally posted by mastakates
Jthomas just wondering what brakes you were considering to install?
-Bendix Ti semi-metalic pads front, stock pads rear
-goodridge 6-line braided steel hose kit w/ valvoline synthetic dot3/4 fluid.
i have everthing but the rotors back from 300 Below.
if that doesn't do it then i will upgrade to eradispeed rotors front and rear and whatever pads they suggest.
jay
san francisco
Originally posted by CACTUSKID
i AGREE THE ORIGINAL BRAKES ARE LACKING , i HAD MINE UP TOO 110 FOR A BIT IN 5TH GEAR AND WHEN i APPLIED BRAKES FOR THE EXIT ....FAAAAADEEEE BIGTIME
oops caps off
oops caps off
i have hauled my car down HARD from 150+ to around 50 before with fresh fluid and stock brakes with zero fade.
the main reason i am upgrading the brakes is because i want a more firm feel at the pedal and, with the cryo-treated rotors, minimal warpage.
jay
san francisco
Originally posted by jthomas
if the fbody came equiped with the rs-a goodyears, then it got the low top speed limit.
I did take my car to ~170 mph one time (had to calculate it by RPM, gearing, and tire size). I could feel the front end coming up some..it made me a little uncomfortable. I would rather do that in a vette.
I was racing an RX7..we were on I-35 at around 3:00 am. I beat the Rx7 and just kept going.
The car had a hypertech on it, and 4.10s! It may not have been able to pull as much of 6th gear as it did without those gears.
actually, that is not true. only the ss option had f1 tires (17" rims), and my z/28 came with the gs-c model on it's 16" rims and a 162 mph top-speed limiter programmed into the pcm from the factory. if the fbody came equiped with the rs-a goodyears, then it got the low top speed limit.
jay
san francisco
jay
san francisco
I hit the 6200 RPM rev limiter in 5th with no speed limiter. I also have the 200 MPH gauges. I did this a couple times. It was always on the same road with a bit of a downward slop. the gauges said 187MPH. This was done on the german autobahn. 170 was pretty easy to hit on the flat also, it was just dificult to find a good clear bit of road to wind the car up that much.
