LS1 Timming Pickup?
Old Jul 17, 2006 | 10:42 AM
"White Knight"'s Avatar
LS1 Timming Pickup?
What does the LS1 engine use for it's Crankshaft Sensor/timming?
Old Jul 17, 2006 | 12:50 PM
SSpdDmon's Avatar
Re: LS1 Timming Pickup?
Ummm...there's a crank shaft position sensor. Is that what you're refering to? Usually, when you do internal motor work and replace pistons, rods, and crank, you need to do a re-learn procedure with a scanner like EFILive or HPT or a Tech-II so the computer knows where each cylinder is at.
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
