LS1 question
Old Dec 29, 2007 | 07:48 PM
ForceFedZ's Avatar
LS1 question
this may sound like a silly question to some but im not too familiar with the LS engine . Buddy of mine is having trouble with his motor and he needs to know if the heads can be removed with the motor in the car. doesnt seem to be alot of room there. Thanks
Old Dec 29, 2007 | 07:55 PM
GhostZ28's Avatar
yeah its possible. Thats the first reaction car guys have to LS1's "omg! there's NO space!" no space= lots of busted knuckles and cussing
Old Dec 29, 2007 | 08:36 PM
ForceFedZ's Avatar
yeah another friend of mine (good mechanic) who has actually done alot of the work on the car says that the valve covers will barely come off and he wasnt sure if the heads would raise up enough to clear the dowel pins. said the pass. side would be no prob. but the fault is on the drivers side. he says the brake booster may be a prob
Old Dec 29, 2007 | 10:36 PM
Zitty'sZ's Avatar
Yeah it's a little tight under the hood but the heads actually come off pretty easy on both sides . The real pain is cleaning out all the bolt holes afterward and I strongly recommend buying a set of ARP studs . They can be used over and over and if you ever have to pull the heads again you don't have to clean the bolt holes anymore and they are way easier to torque .
Old Dec 30, 2007 | 05:51 AM
AL SS590 M6's Avatar
Moderator
Yeah the heads will actually go on and off with heads studs installed. There's more clearance than you'd think.
Old Dec 30, 2007 | 11:09 AM
ForceFedZ's Avatar
thanks for the info guys ill let him know
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
ChrisFrez
Nov 23, 2014 10:33 AM
