ls1.. potential serious problem discovered
Old Jan 6, 2007 | 11:32 PM
  #16
Bayer-Z28's Avatar
LS6 PCV Conversion How-to.. Direct fit for an LS6 motor, slight modification to fit the LS1 Block.
http://www.ls1howto.com/index.php?article=18
Old Jan 7, 2007 | 01:24 AM
  #17
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
hey guys...
yeah i've been gone for awhile... army eod is the answer, yes... been in training for over a year now... bout to head to my first real duty station at ft. drum new york... i'll be in the 725th ord support DET until my real unit (the 760th) from ft dicks moves up there... i'll be a part of a brigade combat team (one of three at ft. drum) and will be directly attached with 10th mountain division, tentatively scheduled to be standing up and deploying to afghanistan this september.
but yeah anyways...
say i didn't want to do a conversion or anything... how do i simply replace what ive got in there now for a new one? can i? i don't even know where it is heh...
thanks for all the info though... you guys rule as usual
Jared
Old Jan 7, 2007 | 08:34 AM
  #18
AL SS590 M6's Avatar
Moderator
Originally Posted by frmula1
hey guys...
Big black tube on the passenger side of the intake where it hooks to the intake, the PCV is inside that tube.
Old Jan 7, 2007 | 09:57 AM
  #19
danziger's Avatar
Yep, you'll feel the PCV inside the soft tubing. Most LSxs use some oil because of the low-tension ring pack...
Old Jan 7, 2007 | 10:32 AM
  #20
myslowcamaro's Avatar
NOTE: You must have the 2001+ style coolant vent tube as well for the LS6 valley cover to fit! All 2001+ LS1's will have this, and any LS1's that have upgraded to the "LS6 manifold" and pipes will also have the new coolant vent tube.
are they referring to the tb bypass?
Old Jan 7, 2007 | 01:37 PM
  #21
Bayer-Z28's Avatar
hey guys...
I have a good chance of going back to Afghanistan this september too. We worked w/ the 10th MTN last year a little. You'll have your hands full up there! Soviet Land mines ALL OVER!
Old Jan 8, 2007 | 09:25 PM
  #22
Mike94ZLT1's Avatar
Go take a look at the front of your block, right above the water pump by the head. Look for a bullseye mark. If it is NOT there, you have an LS6 block already (possible since you have an 02) and an LS6 pcv conversion would be alot easier.
Old Jan 8, 2007 | 09:27 PM
  #23
Mike94ZLT1's Avatar
Originally Posted by myslowcamaro
sad part is i cant tell if you are serious or sarcastic
Totally serious.
Old Jan 9, 2007 | 08:52 AM
  #24
robb4964's Avatar
Originally Posted by km9v
I don't burn oil at all in my LS1
Mine either. No one I know personally has an LS1 that burns oil. I have heard lots about others though.
Old Jan 10, 2007 | 12:21 AM
  #25
RichieRich's Avatar
My LS1 has a small crack in the oil pan and it still doesn't use/ leak as much oil as some of you says yours does. In all my years of mechanicing I've never seen or owned a vehicle that just uses oil. If it's using that much oil under normal driving something needs to be fixed. My first thought would be the valve seals. All you would need is the seals, valve spring compressor, and compressed air to hold the valves up so you could do the valves in the car.
Old Jan 10, 2007 | 02:14 PM
  #26
frmula1's Avatar
k.. well hers the issue... my car came with the ls6 intake manifold but it currently has the ls1 intake manifold with the EGR blockoff plates installed.. (don't ask) I DO have the ls6 block and i have the original stock pcv...
soo what do I specifically have to do???
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
PCLZ28
Dec 24, 2015 05:19 PM
edxiel
Jan 24, 2015 07:40 PM
