Ls1 Pcm ?
Old May 3, 2005 | 01:07 AM
slowpoke96z28's Avatar
Ls1 Pcm ?
do LS1's stay in closed loop at wide open throttle? when these engines first came out, i remember reading that somewhere.
Old May 3, 2005 | 09:57 AM
SSpdDmon's Avatar
Re: Ls1 Pcm ?
Nope. Open-loop at WOT. There's a PE table (Power Enrichment) that the PCM references to get a desired AFR (11.7 or so from factory), which is used along with the data from the closed-loop (cruise) tables (VE-Volumetric Efficiency, LTFTs-Long Term Fuel Trims, etc.). That is why adding a little spark advance @ WOT to get 27~28* and leaning out your WOT AFR to 12.8-13.0 can get you anywhere from 10-20hp over the stock tune.
whitehooptie
Aug 10, 2015 07:02 AM
Jocofire1
Aug 7, 2015 03:16 PM
88IROC_Z
Jul 22, 2015 11:38 PM
whitehooptie
Jul 22, 2015 10:25 PM
mrwz28
Jul 8, 2015 09:11 PM
