Ls1 to Ls6 SWAP! in Trans Am!
Old May 11, 2003 | 01:22 PM
frizankls1's Avatar
Talking Ls1 to Ls6 SWAP! in Trans Am!
Hey guys i got a question for everyone i have a 1998 Trans Am and i spun 3 bearings and made piston slap with one of my heads and bent a rod but I am swapping out my Ls1 for a Ls6 Long Block now my questions are.....
Can I run the Ls6 with my Ls1 Computer and harness the tru power from the motor?
Do I need a Ls6 computer?
Has anyone done this before and ran into any problems and what were they?
Thanks again.... guys This message board ROCKS!
Old May 11, 2003 | 01:40 PM
wrencher's Avatar
You're bolting up the accesories from the F-bod to the LS6 right? Just use your old PCM that will work fine. To use an Y-body PCM is for the throttle cable-less throttle body.( &a few other things) There is not much differance between the 2.
Old May 11, 2003 | 01:44 PM
frizankls1's Avatar
Yeah all my stock ls1 accesories.
From what pace says the ls6 motor can rev out to 6600 RPM no with my stock PCM i owuld need like a tuner like hte predator to rev it more right?
And if i keep the stock pcm i wont have any problems with keeping my stock throttle body and ls1 parts then thats a good point i forgot the throttle body had no cable that would have been a head ache running around looking for parts to substitute for y body parts. Thanks
Old May 11, 2003 | 05:26 PM
KamaroL98's Avatar
how much are LS6 Long blocks going for nowadays?
Old May 11, 2003 | 07:14 PM
frizankls1's Avatar
I paid $5,293.12 shipped freight to a buisness. Its way more to a house.
Old May 11, 2003 | 10:41 PM
KamaroL98's Avatar
Where did you buy it from?
If my engine ever blows, i might as well plan on dropping in an LS6... No point in paying $4000 for another LS1. Im sure there will be some tuneing issues as well to get full power out of it.
Old May 11, 2003 | 10:49 PM
frizankls1's Avatar
I ordered it from paceparts.com yeah tuning is my problem now it is a direct bolt in but im gonna invest in a programmer i think i just cant find a good tuner i think hypertech will be my choice, my first was diablo sport but they dont make tuners for a 1998 trans am only 1999 and up unfortunatly. to harness the tru power you need to rev it out to 6600 RPM but until i tune it i htink the speed ill get will be just enought for now
Does anyone recomend a good tuner for my 1998 trans am with stock PCM?
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
