LS1 handeling comparison?
Old Jul 7, 2003 | 01:05 PM
teke184's Avatar
i may try this in the "road race/autox" forum too...but i figured since it was ls1 specific i'd try here too...
as far as i know the ls1 equipped fbody has all the same suspension as the lt1 equipped cars...
but is there a difference in handling when cornering?
i realize the ls1 brakes are better, which could also result in more/less unsprung weight...does this affect cornering in stock form?
and how about the difference in weight between the iron block lt1 and the alum. block ls1? does that balance the car better? make it more nimble in the curves?
thanks guys
Old Jul 7, 2003 | 08:43 PM
2002Z28SSConv's Avatar
I'll have to come down sometime and let you drive the SS. I've been wanting to do some more barrel fishing. I can help you make that baby handle too.
Old Jul 8, 2003 | 06:13 AM
teke184's Avatar
yeah chuck, i'm always up for some fishing...got some good numbers off the south side of Key West...
as for the car...by the time you get down here i'll have:
bmr sfc, lca, phb, stb...and hopefully some decent rubber to put it all to the ground...
so i'll welcome some more help
Old Jul 8, 2003 | 03:13 PM
The Suspension Technologies 35mm Front Sway Bar was by far the biggest bang for the buck improvement I made. The springs wer a close 2nd. If looks are added into bang for buck equations the springs probably take the lead. Both mods were less than $175.
Old Jul 8, 2003 | 08:09 PM
chuck's Avatar
The stock DeCarbons suck, plain and simple. LS1 F-bodies can handle. Here is some BMW and Porsche track kills shot from my old '98 Z28 1LE. The only mods were: LoudMouth, brake pads, Kuhmo tires and a 5-point harness.
Old Jul 9, 2003 | 01:16 AM
God! I love watching your movies Chuck. Still getting a lot of cornering with all that body lean. You can watch the horizon in the corners and see just how much you were getting. Still looked like it was doing pretty good though. I need a roll bar so I can do track days too.
Chuck
Old Jul 9, 2003 | 06:34 AM
teke184's Avatar
chuck
i'm seriously looking into some springs, although with the ground fx i don't know if it's a good idea. i'm liking the DMS or the BMR which advertise a 1" drop, instead of the 1.5 that i seem to hear from the eibachs.
as for swaybars, i already have a set of BMR 32/21mm solid bars w/ poly bushings waiting to be swapped on from my 96. so that department should be covered. and i agree, they made a huge improvement on my old car...expecting the same from this car
thanks guys
Old Jul 9, 2003 | 11:58 AM
Jason Novak's Avatar
I have DMS springs with ground effects and it gave me just under a 1.5" drop. I don't really have any problems with them unless I go up a steep driveway to fast. You can see a picture here
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
TGGodfrey
Aug 18, 2015 06:08 PM
