ls1 Edit Problems, Bottom end bogging at stops, plz help
Old Apr 20, 2006 | 12:22 AM
  #16
shocker45's Avatar
Re: ls1 Edit Problems, Bottom end bogging at stops, plz help
Originally Posted by AL SS590 M6
Stock MAF ends are good for way more hp than you're running,
yea i know that, but i dont see how this would not help me at all, sure stock ends are good for more. but im sure i gained a little out of these.
Old Apr 20, 2006 | 12:28 AM
  #17
AL SS590 M6's Avatar
Moderator
I really doubt that they helped make power. But they do screw up your ability to get the tune calibration right.
Old Apr 20, 2006 | 01:13 AM
  #18
shocker45's Avatar
k well ill swap em out, see if that helps
Old Apr 20, 2006 | 02:42 AM
  #19
GhostZ28's Avatar
if you like the way the aftermarket maf ends look, just get some high temp engine paint and spray a couple coats on the ends, be sure to tape off the inside though. then sell your expensive aftermarket ones to someone who doesnt know any better
Old Apr 20, 2006 | 08:04 AM
  #20
CollinsAuto's Avatar
The MAF is designed with a screen and a patricular airflow profile in mind. its got electronics to kill airflow noise. In the PCM there is also some filtering done both on the hardware side and digitally in the code to condition the signal. When you modify the MAF you skew all of those filtering strategys. This will cuase massive trouble. Add a good flowing lid and a large camshaft and it gets worse becuase you have alot more wave action taking place in the intake tract due to camshaft reversion etc. the stock ends flow well enough to make 420rwhp on our really stingy in house dyno. Trust me they aren't a restriction. If you feel your MAf is holding you back get a 5pin 85MM MAF conversion setup from someplace like SLP etc.
Old Apr 20, 2006 | 08:13 AM
  #21
Kraest's Avatar
Retired
My stock MAF is good for 471 rwhp.
Old May 9, 2006 | 09:18 PM
  #22
shocker45's Avatar
k ive been playing with the Iac table in ls1 edit. it helped a bit, but im still getting some brutal idle problems. as i approach a light say i put the car into neutral it will drop to 450-500 rpm and i have to tap the throttle a couple times for it to pick back up, then it drops back down. it takes anywhere from 3-10 seconds for the computer to correct itself
anyways i was looking in the tables in ls1 edit, there is a table called "idle air"
in this there are 2 rows, "in gear" and "neutral" my in gear tab all seems normal, but the Neutral row every box is set to "0" so i dont know if this is contributing to the problem, if this was set to zero wouldnt that make the motor get no air at idle in neutral?
also, when it drops right down to 500 sometimes i can hear the airbox trying to suck a lot of air. it creates a loud enough vacuum for me to hear over my engine noise. not sure what this means?
Old May 9, 2006 | 09:25 PM
  #23
PhantomTA's Avatar
Moderator
Whats your idle set at btw?
Old May 9, 2006 | 09:26 PM
  #24
shocker45's Avatar
900 or 950, and at colder temps i think i have it set to 1050
Old May 17, 2006 | 08:02 PM
  #25
gillbot's Avatar
I just put a 224 cam in my wife's car, no hole drilling was needed. Car idles perfect. All I did was "speed density" tuning then I went back and tuned the maf. Runs perfect, no hole drilling needed.
Old May 17, 2006 | 11:00 PM
  #26
shocker45's Avatar
what did u change in "speed density" and also to the maf settings?
Old Aug 30, 2006 | 02:17 PM
  #27
shocker45's Avatar
anyone have any other suggestions? i still havn't drilled my tbody, im really leaning towards that way at this time tho. i dont know any other settings that would allow me to correct this problem.
Old Sep 1, 2006 | 01:23 PM
  #28
Kraest's Avatar
Retired
Didn't I suggest drilling the TB 4 months ago?
Mike
Old Sep 1, 2006 | 05:03 PM
  #29
shocker45's Avatar
yea i got kind of side tracked :P
my tuning software can't monitor the iac tables. so i dont know how big to drill it. and i kind of wanted to avoid drilling but i think it may come to that :P
Old Sep 4, 2006 | 12:46 PM
  #30
Ed Blown Vert's Avatar
What are your IAC's??
When I had the similar cam. I just moved the set screw for the TB to the top. And adjusted the air from there. Didn't have to drill.
