LS1 conversion
LS1 conversion
what's up everyone? what all is involved in putting an LS1 motor into a 93' z-28 or a 95' camaro? has anyone done this and if so, with what kind of results? what has to be done in order for this to be done? your feedback is much appreciated. thanks.
-Daniel
-Daniel
Re: LS1 conversion
If you don't already know, you'll have to replace both the motor and the tranny. Other than that and the wiring, I don't see it being too hard of an endevor. I know a few people have put them in 3rd gens, so you might want to ask them. Other than that, look into any size differences.
You'll also need the radiator out of a LS1 car.
Re: LS1 conversion
Originally Posted by AL SS590 M6
Not worth the trouble. Just build the LT1 or trade for an LS1 car.
I have a friend that did an LT1 swap into his 94 Firebird...
There is a lot of work. He replaced the Motor, Trans, Rear End, Fuel System, Console (A4 ~ M6), Brakes, Dash Cluster, etc... Etc....
Just buy an LS1, or build the existing 93 LT1 to smack around an Stock/Mild LS1
Re: LS1 conversion
you would also need to replace hood...to my knowledge the LS1 will not fit under a stock LT1 style hood....it's not worth the swap, there's too much involved....even if you swap motor, tranny and computer, there's still suspension, brakes etc....
Re: LS1 conversion
Re: LS1 conversion
Originally Posted by 5.7Lsleeper
Why would he replace suspension and brakes? He already has a V8 car. The way I see it, all you need is LS1 motor and trans, ecu, and radiator.
Re: LS1 conversion
Also the K-member is different.
Don't think it's going to be faster, or cheaper, if you are fine with that, then go for it.
When I had my a4 LT1 car, everyone said that I was crazy for swapping out the a4 for a m6. I did it anyway, and never regretted it. Would it have been faster as an a4? yes. Would it have been cheaper to rebuild the a4? yes. Did I want an a4? no.. Now I autocross and road race, m6 is better. Just do your homework before tearing into it.
tdigger9899
Sep 7, 2015 10:56 AM
