LS-1 article in CHEVY Hi Perf.
Old Jul 17, 2004 | 07:33 AM
HeavyChevySS's Avatar
Page 52 of Sept 2004 !!!!
Dyno proven power gains from installing new exhaust on an LS-1.
You need to read the article to find out all the specifics but the
bottom line dyno results were....
stock baseline 295.5 hp @ 5500 rpms
311.5 tq @ 4500 rpms
new exhaust 312.4 hp @ 5500 rpms
325.8 hp @ 4500 rpms
new exhaust w/ adjusted air/fuel ratio
319.2 hp @ 5500 rpms
332.2 hp @ 4500 rpms
these are RWHP #s by the way.
on another note....there is another article in this same issue that shows the power increase from switching from a standard oil pan to a baffled one. Let's just say the HP increase was similiar to the above #s !!! I thought that was pretty cool !
Old Jul 18, 2004 | 03:28 AM
stik6shift93's Avatar
Do you know what kind of exhaust it was? Those number are impressive, generally a catback gives about 7-10hp to the wheels on an ls1.
Old Jul 18, 2004 | 03:13 PM
Actually the article just says the exhaust parts were made and coated by Jet-Hot. They look really nice and shiney Check it out.....
Old Jul 18, 2004 | 03:56 PM
Re: LS-1 article in CHEVY Hi Perf.
You must have meant headers then, in that case those are about normal gains.
Old Jul 22, 2004 | 07:22 AM
YES, headers, Y-pipe, and all the rest too.
Check out the article. It proves alot to the benchraces that are in denial.
Old Jul 23, 2004 | 09:01 AM
Pewter Z's Avatar
Those numbers look right on. When I got my car tuned I went in with a baseline dyno of 291.8rwhp and drove away with 308.2rwhp. Only mods I have are listed below.
I was wondering though, if you've already had a dyno tune done and then you put on a set of Pacesetters (or insert your favoriate Header/Y-Pipe here) should it be retuned?
Old Jul 23, 2004 | 02:33 PM
94ZRiCeKiLr's Avatar
most places give you a discount on a re-tune. the place that tuned my car gave me two free retunes for future mods.
i would definitely get a retune if you can afford it. the headers and y-pipe will cause the motor to run on the rich side, which as you know, will cost you horsepower. my car was running at around 11.9:1 at 6000 rpm before tuning and just getting the A/F ratio up to 13:1 where it should be netted me 15 RWHP.
Old Jul 24, 2004 | 06:54 PM
LS1SS4ever's Avatar
Thats nice, where is the link for the article
Old Jul 26, 2004 | 06:41 PM
no link, I read it in a real paper mag. LOL
cmsmith
Mar 11, 2015 09:55 PM
CARiD
Jan 14, 2015 04:00 AM
formula79
18
Jul 1, 2002 02:39 PM
