low oil light
low oil light is on in my 98 ls1, but has plenty of oil, checked, it before i started and after, just came on , wasnt on the previous day. engine is brand new as well, any reason why, anything to be concered about
Originally Posted by hot936spd
(Post 6872337)
Sent from my PC36100 using Tapatalk |
Re: low oil light
I had this exact problem, and it was suggested to me to change my oil filter to a K&N, I didnt believe it would work but I was desperate to fix it so I changed the oil and put the k&n and it fixed the problem.
This may just have been luck for me or something else, just thought I would share and hope it works for you brother |
Re: low oil light
Originally Posted by OutlawPerforman
(Post 6881579)
Re: low oil light
Originally Posted by AL SS590 M6
(Post 6893213)
The low oil level light is driven by a sensor in the right side of the pan and has nothing to do with the oil fiter. More likely that removing the oil and filling it back up corrected the minor fault with the sensor.
so I'm letting it be since I check my oil ever 2 or 3 days (oil pan gasket leak) and I plan on swapping my ls1 out, so I'll just wait until then to fix it |
