lost oil pressure, but it came back at restart
Old Mar 26, 2008 | 10:05 AM
  #16
cnw8891's Avatar
Originally Posted by 6speedZ28
After hearing some of the horror stories that people with 1998 LS1 f-bodies have had with the oil pump. I am checking that gauge pretty often when I'm out in the Camaro.
I've worried about it since I got the car. Even if the pump turns out to be ok, I'm still going to replace it as soon as I can. I don't need my car to have a heart attack!
Old Mar 26, 2008 | 10:14 AM
  #17
6speedZ28's Avatar
Yeah, its on my list of things to do in the future. The car sees probably 800mi a year so its something that I keep putting off. I better just do it though or it will bite me in the *** one of these years.
Old Mar 26, 2008 | 11:31 AM
  #18
cnw8891's Avatar
AC is busted and leaking oil. The pulley must have frozen up and kept the belt from turning. That would explain the steering going out and the oil pressure dropping. I guess the engine was cutting off.
Do you think it's ok to drive as long as I don't run the AC? I really want to go get some lunch
The puddle:
The leak (notice the bubble):
Old Mar 26, 2008 | 12:04 PM
  #19
dangalla's Avatar
i would not run it at all until you fix it, if it seizes up it will burn the belt right off, like it already tried to do, hence the smoke.
sit back, drink one of those beers and order a compressor
Old Mar 26, 2008 | 12:06 PM
  #20
cnw8891's Avatar
As long as I don't run the AC and the compressor clutch doesn't try to engage, shouldn't it be safe, more than likely anyways?
Old Mar 26, 2008 | 12:08 PM
  #21
dangalla's Avatar
that should be ok i guess, i would pull the fuse at least. maybe disconnect it at the compressor
Old Mar 26, 2008 | 03:56 PM
  #22
Me>you's Avatar
A/C is on seperate belt, take belt off
Old Mar 26, 2008 | 04:05 PM
  #23
cnw8891's Avatar
Hmmm....I didn't realize that. Thanks
I took the AC compressor fuse out. Car runs fine. Now i need to change the compressor. Also, the heater door in the dash is stuck and not letting cold air into the car
I've got some work to do
calaban
May 18, 2020 06:43 PM
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
