Lid problems?
Old Aug 23, 2003 | 09:56 PM
Jilly's Avatar
Lid problems?
I just got my whisper lid from tbyrnemotorsports and after putting it on, I can't get the clasps to stay shut. Is that a common problem or is it just me...maybe I didn't get it on right..??
Old Aug 23, 2003 | 10:01 PM
hurricaine418's Avatar
clasps
are you sure the little flaps on the back of your lid are tucked in the slots. it wont clasp right if they arent.
Old Aug 23, 2003 | 11:21 PM
JaysGone's Avatar
Sometimes it depends on the bellows you have. It might be putting too much preasure on the lid and you have to trim it a bit
Old Aug 23, 2003 | 11:32 PM
My00Camaroz28's Avatar
Woah, someone from Boca Raton....that's where I live....don't think I've seen your car around.
Old Aug 23, 2003 | 11:38 PM
JaysGone's Avatar
Depends on what part of town your in. Im in West Boca and only drive about a half mile to work a day. Rule 1 never work more then 1 mile from home. Rule 2 work only when bored
Old Aug 24, 2003 | 06:54 AM
kick Z tail out's Avatar
Okay, what do you say we get back on topic and help the little lady out?
TTT
Old Aug 24, 2003 | 09:50 AM
ULTIMTEORANGESS's Avatar
make sure the front of the lid is behind the front of your airbox.i had the same problem.after i figured it out its been fine.
Old Aug 24, 2003 | 08:06 PM
Jilly's Avatar
Re: clasps
They were in there, I just had to push a little harder to get them in even more. Seemed to work. Thanks.
Old Oct 6, 2003 | 07:40 PM
Jilly's Avatar
Ok, I'm still having problems with keeping the clasps shut. Can you explain how to trim the bellows. I want to make sure I do it right.
Old Oct 6, 2003 | 08:43 PM
JaysGone's Avatar
Jilly just trim the section at the throttle body end. If its the slp bellows its only silicon and a sharp razor blade will work fine. It will relieve the pressure at the back of the lid allowing it to slip in a little easier. I trimmed off almost 3/8ths to a half inch on mine. Still is a tight fit but much easier to remove to inspect the filter
Old Oct 7, 2003 | 12:32 PM
Jilly's Avatar
Ok, well, I'll try it this weekend and see what happens.
HarleyZ28
Oct 5, 2015 06:23 AM
R@mpage
Apr 20, 2015 10:02 AM
C6LS3
Apr 15, 2015 09:50 AM
CARiD
Feb 9, 2015 09:35 AM
rjc1629
Jan 27, 2015 10:46 AM
