Lid problems?
Lid problems?
I just got my whisper lid from tbyrnemotorsports and after putting it on, I can't get the clasps to stay shut. Is that a common problem or is it just me...maybe I didn't get it on right..??
Re: clasps
Originally posted by hurricaine418
are you sure the little flaps on the back of your lid are tucked in the slots. it wont clasp right if they arent.
Originally posted by JaysGone
Sometimes it depends on the bellows you have. It might be putting too much preasure on the lid and you have to trim it a bit
Can you explain how to trim the bellows. I want to make sure I do it right.
Jilly just trim the section at the throttle body end. If its the slp bellows its only silicon and a sharp razor blade will work fine. It will relieve the pressure at the back of the lid allowing it to slip in a little easier. I trimmed off almost 3/8ths to a half inch on mine. Still is a tight fit but much easier to remove to inspect the filter
TTT
