Left hand in a right hand land part 2
Old Oct 6, 2013 | 02:23 AM
kiwi rod's Avatar
Chev V8 engines are used in Australian Holdens for years in fact your Pontiac GTO is a rebadged left hand drive Holden Monaro
Years ago I played around with high lift rockers in european engines It meant you could run a consevative cam but have the effect at the valves of a real hairy cam the only problem was unless the pedestals that suported the tappets / rockers were bang on for hight then the tappets / rockers would start clawing the valves side ways & premerturely wear out the valve guides.
Has anyone run high lift Tappets / rockers ?
Any advice ?
Rodney
Old Oct 6, 2013 | 01:44 PM
transamtom's Avatar
Re: Left hand in a right hand land part 2
1.85 would be the max on an LS engine.
Old Oct 6, 2013 | 05:04 PM
WhiteHawk's Avatar
You would get much more bang for the buck by doing a cam than rockers. The stock cams are pretty small, and you can get aftermarket ones that will still drive and idle like stock. Lingenfelter has a GT2-3 that I have run with the stock tune with no issues.
-Geoff
Old Oct 7, 2013 | 10:58 AM
kiwi rod's Avatar
I have been told by one of our better tuners down here that if I replaced the camsharft I should look at 222 - 227 duration
570 - 600 lift
111 - 114 lsa
Does the Lingenfelter match these specs ?
Rodney
Old Oct 8, 2013 | 07:56 PM
WhiteHawk's Avatar
570 - 600 lift
111 - 114 lsa
Rodney
No, the LPE is something like 207/220 .571/.578 118. That camshaft you described would be a lot better but you might need to tune it to get the driveability right.
-Geoff
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
CaRParts102
Dec 6, 2014 08:45 AM
