Just put on Hurst T-handle shifter nob. I have a ????
Just put on Hurst T-handle shifter ***. I have a ????
After screwing the spacer nut all the way down there were not enough threads for the T-handle to screw on. It says if there are not enough threads to discard the spacer nut and use a two part epoxy to hold the handle where you want it. I used a maximum strength thread locker instead. I think the two part epoxy would never allow me to take the handle off. Do you guys think the thread locker will hold good enough ??? I used the red maximum strength kind.
actually there's still hope. the green loctite is the strongest on the market. another inexpensive fix is to drill and tap an 1/8 set screw. get a small piece of plastic put it against the threads and tighten down the set screw that will hold for sure.
matt
matt
F'n1996Z28SS
08-23-2023 11:19 PM
