Just got a LS1
Just got a LS1
It was not easy either but i did it I traded in my A4 1997 Z28 Convt. in for a A4 1999 Z28 SS.I didn't think that there was going to be a power difference because the 97 z28 had --hooker long tubes,K&N FIPK and a cutout already, but man was i wrong . Man the 99 feels alot faster and also feels more responsive. But I will miss the old Z. Any tips on making the new z faster will be most welcome.
Thanks,
Thanks,
Re: Just got a LS1
Originally Posted by rwb
Headers, cam, ls6 intake, just the usual stuff will put you up around 400 or more rwhp. Then the fun begins.
Re: Just got a LS1
I put heads, small cam, ls6 intake, and exhaust and made 407 hp. So I think I do know what I'm talking about,and I assumed that he would get good parts. The ls1 responds differently than any other gm motor, 400 hp at the rear tires isn't that unusual.
Re: Just got a LS1
Re: Just got a LS1
Welcome to the world of LS1's.
There is plenty you can do to make the car stonger, just depends on what you're looking for out of the setup. I would start off with the bolt-ons: torque converter, headers, lid, catback, ls6 intake, pulley. It's a good starting point anyway. After that, it just depends on what you want out of the car. You can get pretty agressive with some of the heads/cam setups these days.
Brian
There is plenty you can do to make the car stonger, just depends on what you're looking for out of the setup. I would start off with the bolt-ons: torque converter, headers, lid, catback, ls6 intake, pulley. It's a good starting point anyway. After that, it just depends on what you want out of the car. You can get pretty agressive with some of the heads/cam setups these days. Brian
Re: Just got a LS1
Thanks,
Thanks,
Congrats on it, you will love it
Re: Just got a LS1
You're very vague about your mods. What heads, cam, exhaust? What trans?
Re: Just got a LS1
You have an a4 first of all get 3.73's not 4.10's, they are too deep a gear for automatics. Also get a porgrammer, predator is the best one so you can recalibrate the speedometer and raise the redline. If you can afford it a tc with at least 3500 stall. For lower cost a lid and cat-back should give close to 25 rwhp. I got mine for under $500 installed (did it myself). Sfc's should help get some more power to the ground and lt headers are a must. Also must reccoemnd granatelli maf I really noticed the difference. That should put you in the mid 12 range.
Re: Just got a LS1
First things first. Get a lid and catback. Then definately look at torque converters, LT headers, drag radials and SFC. I would just leave the 3.23 gears in. They are decent for top end, highway mileage and will work well with a torque converter and or N20.
Grats on the new ride and enjoy!
