Isn't the LS6 a bigger block than the LS1?
Re: Isn't the LS6 a bigger block than the LS1?
Originally Posted by TheV6Bird
Nope, LS6 is the same as an LS1, except the LS6 has better oiling passages.
Originally Posted by Silver
i believe the C6 has the LS2 standard right? and the LS6 is still in design phase? i ain't real sure bubba.
The LS6 block has thicker sidewalls. You can't get the over 4"-ish bore w/ an ls1. The LS2 block is the "purfect square" bore/stroke. like 4.02/4.00.... Pretty darn close.
Originally Posted by Strahley
The LS6 454 was bigger, yeah
But the Gen III LS6 is the same size as the LS1, both 5.7 liters. The LS2 is a 6 liter, the LS7 will be a 7 liter
