Introduction (and 2.73s)
Hey all,
Wanted to drop in and say hi. I'll probably be posting here now and then.
I've been on the board for a couple of years, but mostly posted in the V6 section and the Lounge. I just traded in my supercharged 2000 Camaro V6 (sans-supercharger
) for a 1998 Z28. I'm loving the new ride.
My question is, is it worth it to swap out the stock 2.73s my car has for 3.23s or 3.42s? What should I expect ET wise with the 2.73s as compared to the 3.42s?
) for a 1998 Z28. I'm loving the new ride.My question is, is it worth it to swap out the stock 2.73s my car has for 3.23s or 3.42s? What should I expect ET wise with the 2.73s as compared to the 3.42s?
Worth it?
Oh yeah!
I'm soon going to be installing 3.73's in my beast, although you will still notice a huge difference with 3.42's even
. IMO, if you're spending the time/money to swap gears, I wouldn't stop at 3.23's, even though they are lower, 'cause for little difference 3.42's would make toward your gas mileage, you might as well go all out!
I can't tell you exact 1/4 mile improvements, but IMO you should pick up a couple tenths of a second at least
Oh yeah!
I think three tenths going from 2.73s to 3.73s is normal. Maybe .4. Usually, most folks pick up around two or three with 3.42s. On the stock gears, I think they are actually relatively even, maybe the 3.23s a tenth quicker.
The thing about going to a lower gear is that the car will pull a lot harder. You'll also lose some gas mileage, though. I'd just go with a converter.
ducttape1975
Jul 10, 2015 06:29 PM
DETROIT_AREA_00_SS
Nov 5, 2002 12:31 PM
95LT1Z28
Sep 5, 2002 11:12 AM
