intake manifolds?
Old Mar 6, 2005 | 10:43 AM
rossafenton's Avatar
intake manifolds?
Give me your thoughts on the 80mm throttle body and a intake manifold from BBK.
will these mods make the engine sound different?
Tell me your experience and comments.
Ross
98 SS
Old Mar 6, 2005 | 07:57 PM
teke184's Avatar
Re: intake manifolds?
sound different...NO...
more hp is questionable. probably but i havn't seen any tests on those yet so hard to say.
but the LS6 intake gains about 10hp at the wheels so i should imagine the BBK would gain similar.
Old Mar 6, 2005 | 09:50 PM
Greed4Speed's Avatar
Unless you have the mods to support an 80mm Tb it'll probably kill throttle response.
Old Mar 9, 2005 | 07:09 PM
Donny O's Avatar
same as with the old carburated engines. so many times i saw people take a stock 350 and buy a huge 750 or 850 for it and go slower and have drivability problems....because the engine was stock and didn't need more carburation....and I blow them away with my 500CFM 2bbl. know a guy that was putting our about 600+hp on a 750CFM carb. switched toa 850 and gained about 3mph but his et was the same. so even at those power levels a bigger carb didn't make much difference.
Old Mar 9, 2005 | 09:30 PM
1984camaroz28's Avatar
bbk products suck
Old Mar 11, 2005 | 05:00 PM
Antz97ZNJ's Avatar
You'll gain a 5-10 hp from the intake manifold...your stock tb is fine though, you wont gain anything from an aftermarket one
Old Mar 11, 2005 | 06:24 PM
buy a ls6 intake manifold and be better off BBK=JUNK
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
